PrimeMvr's Avatar
Soda blast P&C?
Good evening brain trust!
I am well into my first tear down of a stock 3.0 from an 83 SC. The pistons and cylinders look great except for some carbon in the ring lands and a bit on the top edges of the cylinders.
The heads cleaned up so well with soda blasting that I want to do the same to the P&Cs but I wanted to check with the experts first in case this is not a good idea for the cylinder walls or piston skirts.
Thanks for your valued input!
87 930 - Black - 3.4L/964 cams/K29/Powerhaus IC/6AL-2/B&B dual exhaust/MTX-L/235-315 Toyo R888/18" Kinesis wheels/Big Red brakes/LSD
10 997.2 Cab - Speed Yellow
83 SC Cab - Guards Red [SOLD]
17 NSX - Nouvelle Blue
Old 02-01-2012, 04:10 PM
I use low pressure (60 PSI) soda blasting to clean all my pistons and the external surfaces of all my cylinders.
Scotchbrite is the best cleaning/de-galzing system for the cylinder bores.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 02-01-2012, 05:01 PM
haycait911's Avatar
soda won't hurt anything.
Old 02-04-2012, 02:19 AM
Certified Pre-Owned
BGCarrera32's Avatar
--->Make that WHITE Scotchbrite.
'84 Carrera Coupe
Old 02-04-2012, 06:41 PM
You can safely clean & de-carbonize the pistons and cylinders, however I'd be VERY careful to not blast the bores with soda as that will damage the Nikasil.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 02-04-2012, 08:14 PM
Walt Fricke's Avatar
Steve - my home brew soda blasting was so gentle that I could (and often did) blast my fingers without embedding any soda in or otherwise harming my flesh.
At that low impact range, is this really going to damage Nikasil? Not that I'd expect to blast the insides of a cylinder, because they don't need it anyway. Is a proper soda blaster of much higher impact velocities?
Old 02-10-2012, 09:44 PM
Walt,
The sharp edges of the commercial media can damage the bores with sufficient pressure. Our soda cleaner does an excellent job of removing carbon, dirt, rust and even powder paint so I know it can etch a Nikasil bore.
I'd experiment with a piece of aluminum and inspect it under close magnification to be sure.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 02-11-2012, 12:30 AM
Certified Pre-Owned
Does anyone have a recommendation on mesh size for the soda needed when cleaning up cylinder heads? (mesh size would be on the bag)
'84 Carrera Coupe
Old 02-11-2012, 10:09 AM
Mesh size? Commercial soda media? I got mine in bags from Costco. For baking and whatnot.
Perhaps this is not aggressive enough for carbon. Did a great job of cleaning gunk off of an aluminum tranny case, though, getting into the nooks and crannies.
Made a mess of my driveway.
Next time I start making this mess I will dig into my box of junk parts. I've got some pieces of exploded Nikasil cylinder that would be ideal for such a test. Of course, my spouse has trouble understanding why I hang onto some broken parts.
Old 02-11-2012, 08:39 PM
ASE Master Tech - 35 yrs
larrym's Avatar
Question nikasil
does that also mean a ball-hone is verboten on nikasil?
Originally Posted by Steve@Rennsport View Post
Walt,
"... I am German, and if it has no logic it's meaningless."
914 & 914-6 parts FS 03-2021 www.tinyurl.com/2pmpmv8y
911 parts FS 2022 https://tinyurl.com/911-Parts-FS-LCM
Old 02-11-2012, 09:20 PM
