Help! Clutch Lever Cross Shaft Installed Backwards
I'm in the process of trying to separate the G50 trans from my 3.6 motor, and need to pull the clutch actuating fork cross shaft. The PO has the shaft installed backwards, so that there is no tapped hole in the end of the shaft facing out to use a puller on.
I know this has probably happened before, and would like to know the best way to pull the shaft out. I guess that I could attempt to drill and tap a hole into the end of the shaft that is exposed to me. I wonder if the shaft would just spin making drilling and tapping a hole a PITA.
What else can I do to get the cross shaft out so that I can split the tranny from the motor?
Thanks in advance.
Ernie
98 993 C2S - Arena Red/Beige
76 914/6 3.2 Conversion - Estorill Blue/Coral Red
Old 02-03-2012, 02:52 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Lubricant and gravity?
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 02-03-2012, 03:06 PM
Are you serious? I could spray Kroil in there, but then what? Motor and tranny are sitting on my workbench, so I can't easily tilt them.
Ernie
Old 02-03-2012, 03:10 PM
Ernie, I just reread your post and I guess my reading comprehension is in the crapper today.... Oh well, some days are better than others.............
Bruce has a good idea for separating them, good luck.
Henry Schmidt
Ph: 760-728-3062
Old 02-03-2012, 03:17 PM
Drop the starter and remove the clutch package. At least you can split the engine off
Bruce
Old 02-03-2012, 04:34 PM
Originally Posted by Henry Schmidt View Post
I had no idea they were attached. So bite my head off for trying?
Henry, with all due respect, I have owned and wrenched on Porsches for over 40 years, during which time I have have participated and depended upon this and other forums for advice. I am an amature enthusiast. While I have been a contributor, my knowledge does not approach yours, since you are in the business and have been an active and value added contributor for quite some time on this forum. However, when someone is in need of assistance, as I now am, your humor in response to my request for assistance has left me at a loss. What I was hoping for was suggestions based upon prior experience. What I got from you was flipant arrogance.
I apologise for this repsonse; but, frankly at this juncture the last thing I need is sarcasm or misdirected humor.
Respectfully,
Ernie
Old 02-03-2012, 04:58 PM
Bruce,
I have the engine/tranny sitting on my workbench. I have the starter pulled. How, do I now pull the clutch without first pulling the cross shaft? Please clarify.
Thanks for your response.
Ernie
Old 02-03-2012, 05:11 PM
Originally Posted by earossi View Post
snip.....
Respectfully,
It wasn't sarcasm, I just read your post incorrectly. I'm sorry you're having a bad day but I was trying to help.
BTW: on the internet sarcasm is generally posted in green.
Henry Schmidt
Ph: 760-728-3062
Old 02-03-2012, 05:30 PM
I would guess you would remove the bolts holding the pressure plate to the flywheel.
-Andy
Old 02-03-2012, 06:48 PM
Andy beat me to the answer
Bruce
Old 02-03-2012, 07:23 PM
Andy,
Thanks for your response. Can I access the pressure plate bolts through the starter access hole? I'm not down in the garage and can't visualize it. If so, I can bar the engine over and take the bolts out slowly. Then, when I separate the trans, the plate and disk should remain on the trans output shaft as I pull the trans, right? That will still leave the release lever and cross shaft installed in the bell housing. Is there access to the back side of the shaft so that I can tap it out once I have access to the interior of the bell housing?
Ernie
Old 02-03-2012, 07:37 PM
Andy,
OK. Took a look at it, and I can see that I can pull the pressure plate bolts one at a time. I am attempting to epoxy a bolt to the bare end of the cross shaft hoping that it will not take a lot of force to pull the shaft out. I'll give that a try first, and if that fails, I'll take your idea to remove the bolts holding the pressure plate to the flywheel.
Ernie
Old 02-03-2012, 08:30 PM
Thought, when you remove the steel retainer there is a fiber dust cover that comes off to reveal the threads of the cross pin.
Did you remove the dust cover with the steel retainer?
Bruce
Old 02-04-2012, 05:29 AM
Bruce
Did not see any plastic cover or plug behind the shaft retainer. My car is a 98, so may be a little different than earlier years (I am finding that on other items as well). On the tranny, there was a plastic cover plate with a gooseneck down facing vent over the cavity in the trans case. Three bolts and the cover comes off. Removing the cover reveals a kind of triangular shaped cavity about 2" deep. There is the expected metal retainer held in place by one bolt. When I removed the retainer, I expected to see the threaded end of the cross shaft; however, what I saw was a shaft without a tapped hole. No other plastic or metal items in the cavity. I will look again this morning and try to take a picture.
Ernie
Old 02-04-2012, 06:39 AM
I was talking with knowledge of the late 911 and the C-2. Thants my references.
Bruce
Old 02-04-2012, 09:35 AM
KTL KTL is online now
Schleprock
KTL's Avatar
That cross shaft is not hardened, so you should be able to drill it fairly easily. Just make sure to use a new bit and some cutting fluid.
Or else weld a bolt on to the end of the shaft? You certainly can't get the ground clamp onto the shaft itself. But the alloy case should be a decent conductor to get "continuity" to the shaft so you can weld on it.
Kevin L
'86 Carrera "Larry"
Old 02-04-2012, 09:54 AM
Epoxied bolt worked great! Cross shaft came right out. Thanks all. Back to the teardown.
Do any of your guys have a source for the rubber ells and tees needed to rejuvinate the vacuum operated constols system on this motor? Porsche carries some of the fittings, but some them are marked as NLA. Those that are available are grossly expensive.
Ernie
Old 02-04-2012, 11:19 AM
I've found such "L's" and "T's" at Ace Hardware. They are for drip irrigation systems. Probably not the best quality for your vacuum system but they might be better than the old parts.
-Andy
Old 02-04-2012, 11:50 AM
