porsche rocker arm rebuilder
I am looking for a rebuilder for 911 rocker arms.
any info will be greatly appeciated
Old 09-08-2012, 10:22 AM
I can do those for you, properly.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 09-08-2012, 01:49 PM
Mo money = mo parts
Originally Posted by steve@rennsport View Post
i can do those for you, properly.
+1
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 09-19-2012, 01:19 PM
KTL KTL is offline
Schleprock
KTL's Avatar
cgarr can do them too.
Kevin L
'86 Carrera "Larry"
Old 09-19-2012, 02:25 PM
ROW '78 911 Targa
timmy2's Avatar
I sent mine to cgarr recently. He did a great job for a very reasonable price with a fast turnaround.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-19-2012, 05:00 PM
rocker arm rebuild
How do I contact cgarr?
Old 09-19-2012, 09:15 PM
ROW '78 911 Targa
timmy2's Avatar
Here is his latest post.
PM or email him by clicking on his user name. E-mail may be better.
Valve guide interferance
Dennis
Old 09-19-2012, 10:21 PM
John Dougherty, aka Camgrinder, of Dougherty Racing Cams rebushed and reground mine when he reprofiled my cams. It was around $400 if I remember correctly.
Old 09-19-2012, 11:54 PM
ROW '78 911 Targa
timmy2's Avatar
cgarr charged me under 1/2 of that amount. No rebushing needed, but that would only add another $30 or so.
Old 09-20-2012, 07:51 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Craig (cgarr) also uses self-lubricating lined bushings that so far perform outstanding in our application. We have them in a number of engines (two in Craig's fleet, two in mine and cstreit's Motodelta fleet, plus however many Craig has done for other customers) and they continue to perform outstanding.
Kevin L
'86 Carrera "Larry"
Old 09-20-2012, 07:59 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Supertec is rebuilding rockers with an entirely new process.
First the bushing is removed.
The rocker is bead blasted and inspected.
The the whole rocker is black oxide treated.
Then the adjuster treads are cleaned and restored with a forming tap. (read rolled)
A new SDU bushing is installed an sided. (greatly reduced coefficient of friction .05vs .34 for P/bronze and improved heat transfer)
Next the rocker pad (cam follower) is surfaced.
At this point the rocker is sent out for dry film lubricant.
After that, the bushing is drilled and the entire part is cryogenic treated.
We have sets in stock ready to ship. One day turn-around for most types.
$420 exchange
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 09-22-2012, 03:09 PM
Trophy's Avatar
Henry,
Will you also modify mechanical rockers for use in a 993 converted from hydraulic?
Steven
1995 - 993 RS Tribute - 4.0l Engine plus other stuff...
2005 - Touareg V8 Tow Vehicle
Old 09-25-2012, 06:03 PM
Originally Posted by Trophy View Post
Henry,
Sorry but at this point we're only rebuilding early style rockers.
Henry Schmidt
Ph: 760-728-3062
Old 09-25-2012, 06:40 PM
I just rebush early non hyd. Rockers and dont drill the oil holes and use 993 shafts. With the correct grind on the camshafts will complete the conversion.
Old 09-26-2012, 02:59 PM
Trophy's Avatar
I have a full new set of mechanical rockers I have bought. From what I understand I have to either put new bushings in them or turn them around to prevent an oil leak.
I also have a set of new (couple hour old) appropriate cams.
Steven
Old 09-26-2012, 03:02 PM
Are 930 rockers the same?
1987 GP White 930
1977 Ford Bronco
Old 09-27-2012, 01:14 PM
Yes, but we may not have them in stock. The later 930 rockers seem to suffer failure more often than the earlier rockers so we don"t have as many cores.
Henry Schmidt
Ph: 760-728-3062
Old 09-27-2012, 01:56 PM
Yes you can just turn the bushings to block the oil holes. If I remove the I replace them with new.
Old 09-27-2012, 03:55 PM
Henry, I would worry about the effect of Black Oxide treatment and the influence it may have on the fatigue life of relatively high strength steels.
I believe that earlier this year (April/May) Sikorsky ceased using this process due the 'embrittlement effects ' and subsequent component failure.
Another Helicopter manufacturer in the UK has observed fatigue life reductions of up to 80% and has followed Sikorsky in ceasing to use this process.
Shortly after this information appeared a revised Mil Spec was produced (MIL MIL-DTL-13924D) outlining new de-embrittlement procedures.
Old 09-27-2012, 05:10 PM
Thanks for the heads up. We will watch for any inkling of failure due to black oxide.
It might be interesting to know what black oxide process on what material your study sites?
Our parts are processed in a room temp solution.
I believe the rockers are cast iron. Are you suggesting there is any information about failure in this type of material?
Interesting reading:http://machinedesign.com/article/black-oxide-passes-hydrogen-embrittlement-test-0607
Henry Schmidt
Ph: 760-728-3062
Old 09-27-2012, 08:52 PM
