Porsche Crest 2.7 rebuild
On an engine that has been properly maintained. How many miles should you get out of a 1977S 2.7 that has been totally (top and bottom) rebuilt. The work was done by one of the best Porsche shops in San Diego. The rebuild was done when the vehicle had 111,000 miles. Case savers etc when part of the rebuilt.
Old 10-21-2012, 09:39 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Life of the engine is dependent entirely on how is was used and the temperatures it saw during operation.
With spirited driving 60-70K would be a stretch.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-22-2012, 06:33 AM
bump
Old 10-22-2012, 08:25 AM
It really depends on the quality of the rebuild: what was replaced and how well the machine work was performed.
With strict oil temperature control, I've seen properly done 2.7's last up to 180K.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-22-2012, 08:33 AM
Steve I am looking at doing the top and bottom when I do rebuild.
I would like to 964 camshaft and take a hard look at piston size.
Right now the car is running great, just want to make some plans.
Old 10-22-2012, 09:02 AM
Bear in mind that these are NOT inexpensive to rebuild due to the extensive machine work required whenever the case is opened up.
I would recommend maintaining the same bore size for durability.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 10-22-2012, 09:40 AM
bump
Old 10-22-2012, 07:09 PM
ROW '78 911 Targa
timmy2's Avatar
Probably less expensive in the long run to get a used 3.0 or 3.2 and rebuild it over time while you drive the 2.7.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 10-22-2012, 09:04 PM
Air Medal or two
afterburn 549's Avatar
Mine was all original. It had 12000 on the clock at tear dwn.
(Some time in its life the thermal crap had been removed and a real fan installed)
The guides had enough clearance to drive a Trk between valve stem and guide ! (You could actually wobble the valves.)
It did need everything .....But it was running ! LOL
It had lived most its life in the Seattle area..(Not too hot)
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 10-23-2012, 06:26 AM
