nuts
All good suggestions, be sure to torque the rest of your head nuts down before fighting it, they get kind of "sprung" with only one being tight
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 12-18-2012, 12:49 PM
Straight shooter
Lapkritis's Avatar
Originally Posted by john walker's workshop View Post
nice if they were all like that.
The pictures OP posted were air cooled ... are there any air-cooled that the studs are not visible on cylinder or head when assembled? I'm not aware of any.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 12-18-2012, 01:28 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Lots of cylinders are cast with bores for the studs. I believe the 95mm and later are all "contained" studs
When Porsche increased the stud spacing from the 2.7 to the 3.0 is when the change was made?
Kevin L
'86 Carrera "Larry"
Old 12-18-2012, 01:43 PM
All 3.0 from 76 on are contained and not visable.
Bruce
Old 12-18-2012, 03:56 PM
Straight shooter
Lapkritis's Avatar
That's too bad. Ugh.
Old 12-18-2012, 06:40 PM
