nuts
All good suggestions, be sure to torque the rest of your head nuts down before fighting it, they get kind of "sprung" with only one being tight
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
Straight shooter
The pictures OP posted were air cooled ... are there any air-cooled that the studs are not visible on cylinder or head when assembled? I'm not aware of any.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Schleprock
![]() When Porsche increased the stud spacing from the 2.7 to the 3.0 is when the change was made?
Kevin L '86 Carrera "Larry" |
All 3.0 from 76 on are contained and not visable.
Bruce |
Straight shooter
That's too bad. Ugh.
