johnman001's Avatar
Vertex alternator housing
I'm rebuilding a stock 3.2 and upon cleaning/inspecting, I notice the fan housing has a big crack in it.
Has anyone used one of the Vertex Aluminum alternator housings and fan? I received one today and without fitting it, the part does look good. Not quite die-cast smooth, but reasonable for a reproduction. I will be fitting it this weekend.
After looking at the old housing, I'm wondering if I can TIG weld it with magnesium filler rod (AZ101). Anyone have any experience in repaired alternator housings?
I should post a pic.
John Flesburg
2016 981 Boxster S.................| 1983 911 Turbo - (White)
1974 911 3.2 - Red Car........... | 1974 914-6 3.2 - (Silver)
1974 914-6 3.2, GT -(Red).......| 1974 914 - 2.7 GT Clone (TBD - Saphire?)
1971 914 (TBD)..................... |
Old 03-08-2012, 08:05 PM
304065's Avatar
If it were a fan housing from a four-cam carrera I'd say weld it in a shielding box.
It's not-- these are freely available in the classifieds.
Maybe the quality of the Vertex part has improved, but the last one I saw would make a nice holder for a potted plan
The fan spins at a multiple of engine RPM depending on pulley configuration so this is not an area to take any chances.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-09-2012, 03:56 AM
A good friend of mine is in the process of making a billet AL version of the fan housing. He has the CAD done, and is working to find someone who can mill it. I've heard mixed reviews of the Vertex one, everything from its perfect to it's not worth a darn thing.
Old 03-09-2012, 07:11 AM
johnman001's Avatar
Thanks.
I'll post pics this weekend. It's aluminum, and it's cast. I'll know more when I go to fit it up, but frankly, it doesn't look bad.
Btw, if these are so freely available 304065, send me one!
Old 03-09-2012, 08:52 AM
The 9 Store
I bought a vertex to replace a cracked shroud. Visually it's not as nice looking as oem but the alternator and fan fit perfectly. I didn't want to try to repair a 30+ year old part that would probably just crack again. Salesman at vertex told me this is version 3 and the fit is improved from earlier models. Little heavier since its aluminum instead of Mag.
sjf911's Avatar
I have one and it is rather crude but works.
Sapere aude
1983 3.4L 911SC turbo. Sold
Old 03-09-2012, 09:58 AM
The 3.2 alternator housings are prone to these cracks and are very hard to find without them. In the past few years I have seen close to a dozen of these and only found 1 or 2 that were crack free.
The 90 watt alternator in the 3.2 is longer and, as a result, the alternator mount face on the shroud got thinner making these units prone to cracks.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 03-10-2012, 05:31 PM
johnman001's Avatar
I fitted the one I have and it seems to be just fine. Not Die-Cast magnesium, but looks to be of good quality none-the-less.
John Flesburg
Old 03-10-2012, 05:57 PM
johnman001's Avatar
Any comments? I think the Vertex unit looks reasonable. Not polished chrome, but it seems like it will work and has no crack.
John Flesburg
Old 03-14-2012, 05:53 PM
I got a vertex housing a year ago. I dropped my new valeo alt into it and looks like the thru bolts are not long enough. Not a problem in your case?
Did you also get the vertex fan? Is there a difference between oem and vertex?
Old 03-14-2012, 06:19 PM
In my mind the questions is, did Vertex do anything in their design to eliminate the chronic cracking problem in these late alternator shrouds?
Tom Butler
1973 RSR Clone
914-6 GT Clone
Old 03-15-2012, 03:56 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The alternator fitment in terms of bolt length might be the size/amperage of the alternator? They come in various sizes for different years to account for the current demand of the car. The later cars had more electrical stuff and thus the need to up the wattage of the alt.
Tom was gracious enough to share this chart he made in past posts. It tells a lot of the story.
I'd be curious to know the dimensions of the Vertex housing to see how it compares to all the other variants Porsche made. Does Vertex sell just one size fits all or do they make different sizes?
Kevin L
'86 Carrera "Larry"
Old 03-15-2012, 07:20 AM
The 9 Store
Aluminum vs Mag. Don't know if the part is thicker since someone bought my old cracked shroud. Certainly is heavier in weight. Even if it was the same, another 30 years of use would suit me. NOS would be nice but way beyond my means even if still available. Flat6pack (Bruce) told me he is a fan and he sure knows WAY more than me.
Old 03-15-2012, 09:11 AM
The 9 Store
Google there website. They have many sizes. I called and ordered on the phone to make sure I ordered correct one. Showed up 2 business days later.
Old 03-15-2012, 09:14 AM
johnman001's Avatar
Mine fit with no issues. All the alternator bolts were just the right length for the housing they sent.
I like it. I only wish it had the part number instead of Vertex and the phone number.
It is a bit heavier and from what I understand, the aluminum housing should be less crack prone than the magnesium housing. Heavier, but stronger.
John Flesburg
Old 03-15-2012, 04:15 PM
vmisquez's Avatar
I've TIG welded these a with AZ rod. use thinest rod you can get and make light passes to build up a base for the final welds. I do this to prevent the impurities from surfacing and ruining the final welds. Too much heat will bring the impurities to the surface. Use a dental tool to clean out pockets when the impurities surface.
Old 03-30-2012, 04:57 PM
Well, we tried to weld the cracks in my fan housing last night. The mag corrosion was so deep the weld would not take. So I am off to buy a new vertex housing, I will post pictures when I get it.
Signature Phrase " CATCH ME IF YOU CAN"
1988 Porsche 930 "Squerly" Built by "Porsche Doc"
1974 Porsche 911 (2003 - 2012)
2000 Boxster S (2006 - 2008)
Old 05-09-2012, 06:00 AM
the quality was of an aluminum cast part. It seems to be pretty good quality.
I had just a couple of issues with it but nothing major.
pictures will follow of the problems.
Old 05-19-2012, 08:13 PM
the casting had slightly different positions for these two bolt holes at the top of the casting. No big deal really. I just drilled the shroud to match the housing.
This is going on the 930 so I was worried about depth of housing, ect...
The alternator was TIGHT going in...I mean tight! However it did go in...so It problaby will be a real ***** getting it out. But all in all, it was a good by, I would recommend it. next time I take it out, I will shave off the "Vertex" and the part number, make it smooth and powercoat it.
Thanks for the help and info!
Old 05-19-2012, 08:20 PM
I got a Vertex alternator mount not long after they started offering them. With the engine out a few months ago, I noted that the timing mark on the mount was 5 degrees ATDC. So I ran for those several years with the timing 5 degrees retarded from what I thought it was running.
Old 05-20-2012, 04:44 AM
