Straight shooter
Lapkritis's Avatar
That's the point... exactly how you go about removing broken exhaust studs from aluminum cylinder heads for example. That area is far more delicate than this...
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 06-10-2013, 02:30 PM
dtw dtw is offline
GAFB
Well too late now...but I was going to suggest securing the engine, then attaching a strap around the transmission and pulling it with a come-along or ratcheting tie-down.
If extremely high tension on the transmission didn't result in separation, then alternating rounds of heat/mallet/penetrant could be applied (while transmission still under tension) until it broke free.
Next time.
Several BMWs
Old 06-11-2013, 10:06 AM
Originally Posted by keynsham1 View Post
Anyway, I have just come in from my garage having separated the engine and gearbox.
The slot was made with a Dremel tool and doesn't penetrate the casing
I still have to get the remaining parts of the stud out of course which I am not expecting to be easy. I tried drifting the part in the bell housing out and it really will not budge. I will have to drill it I expect, but at least I have got good access now.
As for the slot, I will fettle this to be perfectly parallel, bond in an aluminium packer and trim to match the outer casing shape. It will be invisible and structurally functional.
Well done - You have jumped a hurdle that I hope to never encounter!!
Your 'shim' should work, however you could also insert a tube the exact width of the bell housing mount & let that take the bolt head pressure.
BTW which Dremel wheel did you use to cut the slot? I always thought they were too lightweight for a task like this ( I might buy one now).
I hope things will be straightforward for you from now on. Good luck
Peter in Australia
Old 06-12-2013, 04:54 PM
fred cook's Avatar
Removing exhust studs
If the stud is broken flush with the head, the only choice is to drill it out or have it removed using the EDM process. If there is any stud left to grasp, a little heat from a propane or Mapp gas torch will do the trick. Heat the head in the exhaust port until you see the thread locker on the stud start to bubble. Then, using a stud remover or a small pipe wrench, turn the old stud out. I just did a set of heads this way to allow for installing longer studs. Worked like a charm!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-12-2013, 06:25 PM
Straight shooter
Lapkritis's Avatar
If it's broken flush to the head you can put a nut of appropriate size over it and fill with weld. Just another trick...
Old 06-12-2013, 07:02 PM
I have a small Dremel tool. There is now a larger one that looks like a small angle grinder. There is a cutting disc you can get for it which is approx. 3" in diameter. I used one of these on my smaller Dremel. I had to use some washers to make it fit as the hole in the cutting wheel is much bigger than the small screw on the tool itself.
The stud remaining in the engine casing is not protruding much and I will need to drill it out and use a stud extractor. Heat will be applied! The remaining stud in the bell housing will not budge. I have tried drifting it out but it is almost as if it has become part of the housing itself! I will need to drill this out but it's in an unthreaded hole so it should be relatively easy.
I should probably mention at this point that I am an trained aircraft repair stress engineer and so overcoming this type of problem with complex metallic structure is really my day job! And yes, aircraft do corrode!
Old 06-13-2013, 11:49 AM
At last after a delay of a month or so whilst I got the right tools, begged and borrowed engine crane etc, I now have my engine on a stand and ready to work on.
Flywheel is looking a little rough though!
Oddly, the clutch action was perfect!
This is becoming more of a labour of love rather than a quick head stud fix, but I keep telling myself it will all be worthwhile in the end.
Old 07-10-2013, 02:07 PM
Discseven's Avatar
...Anyway, I have just come in from my garage having separated the engine and gearbox.
The slot was made with a Dremel tool and doesn't penetrate the casing as you can see from the pictures below...
I know some don't like to see modifications like cutting into a trans. I think it's a great solution Keynsham1.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 07-10-2013, 08:23 PM
Thanks for your support! I never got any useful alternatives from this site to my problem, and it has worked well for me! I wonder how many people actually do this type of job. It is a massive task to remove an engine and gearbox and replace head studs!
Old 07-11-2013, 04:54 AM
Smoove1010
Smoove1010's Avatar
Keep at it Keynsham - you had an unusual hurdle to clear, but you're back on track. Think if this as a series of small projects instead of one big one - that's what I did. Don't forget to have fun along the way. The satisfaction you'll feel at the end will make it all worth it.
Good Luck!
GK
Old 07-11-2013, 05:16 PM
Discseven's Avatar
Smoove1010 makes an excellent point... have fun along the way!
Recently had my 3.2 out to deal with a variety of things.
Will 2nd the motion on "series of small projects."
Karl ~~~
Old 07-14-2013, 10:17 AM
Any progress reports - are you working in the shade?
Hi - Curious on how your project (or series of small projects!) is progressing.
I read that you are having wonderful summer weather, while we in Australia have miserable cold rainy days. Are you working outside under a 'shade tree'?
Peter in Melbourne
Old 07-20-2013, 05:38 PM
I'm glad I came across this thread. I too am in the middle of doing much of the
same aside from the stud. I had tons of little leaks and doing the ole "while I'm
at it routine."
While reading this a light when off. I found what I thought was a crack in my
bell housing. I know am convinced that at some point someone did the exact
same to remove my trans. Though going through my records I have been unable
to find where any clutch work had ever been done. This was odd to me because
I have what has looked like every single receipt for all the prior jobs on the engine.
So, your solution appears to be one that has been done before.
What I have been searching for is torque specs for the oil cooler bolts. Also, I
found that one of my lower bolts (closest to the rear of the engine) that hold on
the cooler was missing its washer. So, either Porsche only puts washers on
3 of the bolts or, again, the o rings had once been replaced and the washer
was not reinstalled. Did you have all 4 or did yours only have 3 as well? Would
you happen to know those torque numbers?
Thanks, keep pluggin along
Scott
Old 07-22-2013, 03:59 AM
I have ground to a halt at the moment. I am waiting for Pelican to deliver to me the two tools needed for removing the camshaft nuts. It seems impossible to get them in the UK. No second hand ones I could find. Porsche now claim they are NLS, and no dealer will lend them to me. I have an email from Pelican saying they are on order and should be sent out my the end of the month. I am sceptical. They also have to get to the UK and through customs so it could be a few weeks before I can continue. Very frustrating. I have had the flywheel skimmed in preparation for the new clutch, but little else.
I have ordered all the parts I think I need now so these should be arriving soon. I already have a pile of parts to fit and it is getting bigger.
Meanwhile the engine is sitting in my garage on a stand looking very sad for itself!
Old 07-24-2013, 02:12 PM
I am sorry to hear about the misfortune.
While you are waiting for the tools and the rest of the parts: I would take this time to clean clean clean as much as you can.... it's boring, but it will be rewarding when you're able to get back to work...
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 07-25-2013, 12:51 PM
fred cook's Avatar
Plan B
You can use a 46mm socket and an air wrench to remove the two camshaft nuts. I used a lower setting on the air wrench and kept hitting the nut until it just started to turn. Once it was loosened about 1/4 turn it came off easily. Use the chain tensioner wheel to keep the chain tight while doing so. You can back completely off the rocker adjustments if you are worried about damaging a valve.
FEC3
Old 07-25-2013, 06:29 PM
webrest's Avatar
Next weekend I am going to drop the engine from my 911SC due to the usual head stud problem. I have four broken, and three completely missing which I suspect was from the previous owner!
I have a few questions which I am hoping somebody can help me with?
Firstly, I assume there is a vacuum pipe for the brake servo (booster). Where is this located on the engine?
Is there a wiring loom connection at the back of the engine? I have disconnected all the wiring on the left side but I have read that there is more behind the engine?
Is the engine earth strap the one that is actually attached to the front end of the gearbox just in front of the mounting cross beam?
If I raise the car and rest it on its wheels to take the engine out, I assume when the engine is released onto my home made supporting pallet, that the car will move upwards on the suspension? Does anyone have any experience of this happening?
Thanks in advance!
Keynsham1,
If your SC is a RoW car (no lambda), there would be no wiring connector at the back of the engine. However, if your car is a non-Euro or RoW car:
'78-'79...........................no extra connector at the back side.
'80................................there is a 6-pin connector for the ECU.
'81-'83...........................there is a 12-pin connector for the ECU.
After the removal of the engine, the rear end of the car will go up several inches due to the removal of the load (engine).
Tony
Posted from Pelicanparts.com App for Android
"When I was a kid I used to pray for a bike everyday but then I realized that God didn't work that way so I stole one and asked him for forgiveness"
'85 Carrera Coupe Dk. Blue, '64 Thunderbird Brittany Blue
'68 Lotus Elan S4 Coupe Red, '62 Daimler SP250 [Dart] BRG
Old 07-25-2013, 10:12 PM
Thanks for the update. I am learning from your rebuild already!
I havent started work on mine yet - but I have enquired around and managed to to get a local Pelican to agree to lend me these 'hard-to-get' tools when I commence my own project to fix the 3.0 head studs.
I hope its plain sailing with yours from now on.
Regards Peter in Melbourne
PS: Do you live in the village of Keynsham? I did some genealogical research for a very elderly lady in that town. She has since passed but it was fascinating detective work, as she thought she had an Australian connection.
Old 07-26-2013, 05:57 PM
fred cook's Avatar
46mm Crows foot tool
I have one of these that I won't likely need again. It was used one time to remove the cams from my SC engine. If you are interested, I will sell you this one at a reduced price. Don't know what the shipping would be from the States, probably somewhere between $35 - $50. If PP isn't able to ship the one you've ordered, at least now you have a backup plan!
FEC3
Old 07-27-2013, 03:05 AM
I have just emailed Pelican to see if they will ever have these tools, otherwise I will be in touch! Thanks for the offer. You say 'one of these'. are you talking about both socket and crows foot or only one of the tools?
Old 07-29-2013, 01:35 PM
