Walt Fricke's Avatar
964 Cam setting
What is the overlap valve opening spec for timing these cams?
Is this what one would use if installing this cam in an SC or 3.2?
Old 08-03-2013, 09:21 PM
1.26mm
This is the spec sheet that came with my 964 grind #40 from WebCam.
Hope it's of some help.
Old 08-03-2013, 09:38 PM
Sorry for breaking in here... what is "grind #40"? Are there different 964 profile details?
I am about to do the same thing as Walt.
Old 08-03-2013, 09:45 PM
Grind # 40 is WebCam's 964 cam grind. It's the same profile as a stock 964 cam.
Old 08-04-2013, 07:57 AM
I used 1.8 per Daugherty Racing Cams recommendation on my 3.2 with stock pistons and 964 cams.
Old 08-04-2013, 09:00 PM
1.8 as well on an 83 SC. Stock pistons.
1983 SC
Blog
Old 08-04-2013, 10:28 PM
what if one had an SC with non-stock (Euro) pistons and used the 964?
Old 08-04-2013, 11:14 PM
Setting cam timing so an intake valve is open 1.8mm at TDC overlap before the intake stroke with valve lash at .004" would be advancing cam timing a little from stock 964 settings and that should make a little better lower to midrange torque and probably take away a little top end power.
I'm no expert but thats how I understand it.
Old 08-05-2013, 05:00 PM
A friend did 2.00 with 964 cams and JE pistons.
gary
70T coupe forever almost done
88 Carrera Targa diamond blue
Old 08-24-2013, 09:58 AM
