| Registered Join Date: May 2004 Location: Boulder, Colorado
				964 Cam setting
			What is the overlap valve opening spec for timing these cams? Is this what one would use if installing this cam in an SC or 3.2? | ||
|  08-03-2013, 08:21 PM |
| Registered Join Date: Jul 2006 Location: S. Florida
			1.26mm This is the spec sheet that came with my 964 grind #40 from WebCam. Hope it's of some help.   | ||
|  08-03-2013, 08:38 PM |
| Registered User |
			Sorry for breaking in here... what is "grind #40"?  Are there different 964 profile details? I am about to do the same thing as Walt. | ||
|  08-03-2013, 08:45 PM |
			Grind # 40 is WebCam's 964 cam grind. It's the same profile as a stock 964 cam.
|  08-04-2013, 06:57 AM |
| Registered Join Date: Jul 2008 Location: Spokane WA
			I used 1.8 per Daugherty Racing Cams recommendation on my 3.2 with stock pistons and 964 cams.
|  08-04-2013, 08:00 PM |
| Registered |
			1.8 as well on an 83 SC. Stock pistons.
|  08-04-2013, 09:28 PM |
| Registered User |
			what if one had an SC with non-stock (Euro) pistons and used the 964?
|  08-04-2013, 10:14 PM |
			Setting cam timing so an intake valve is open 1.8mm at TDC overlap before the intake stroke with valve lash at .004" would be advancing cam timing a little from stock 964 settings and that should make a little better lower to midrange torque and probably take away a little top end power.  I'm no expert but thats how I understand it. | ||
|  08-05-2013, 04:00 PM |
| Registered Join Date: Jan 2006 Location: Clayton NC
			A friend did 2.00 with 964 cams and JE pistons.
				__________________ gary 70T coupe forever almost done 88 Carrera Targa diamond blue | ||
|  08-24-2013, 08:58 AM |
