I haven't tried extending the 622 yet, but luckily my intakes are very good so I will only lap them
I had no idea this engine would take this many hours to complete... I'm used to working on 4-5cyl vw/audi engines, so when I started this I was planning to have the engine back in the car in a couple of weeks, yeah right
Old 02-28-2014, 02:41 PM
While I'm waiting for my new valve guides I drew a cylinder holder tool you can make if you have a 3D printer
Porsche 911 cylinder holder tool by neffets - Thingiverse
Old 03-03-2014, 02:14 AM
Awesome project, any updates?
I'm looking into doing a similar ITB setup.
Old 05-06-2014, 12:15 PM
just a quick update, cylinders have been nikasil plated and bored/honed to my dimmensions by US chrome, cost $189 per cyl, and are on their way back to me
I will post pictures and do a dimmension check and RA measurement when I get them
Old 07-30-2014, 07:06 AM
1984 Porsche Carrera
ozracer's Avatar
Wow thats cheap what were they bored to we pay over 400 bucks here per cylinder there is only one place in the country that nikasils so we are stuffed.
Old 08-01-2014, 05:16 AM
Got my cylinders today
I was suprised that there where no documention that verify they are made to my spec.
Anyway i will measure them tomorrow including the surface roughness RA.
DC-30 camshafts are in the mail as well
Old 08-06-2014, 02:07 PM
I also got 1,5 spare 2.7 engine today, not sure what I'm gonna do with it, maybe i'll make a coffe table out of it...
Old 08-06-2014, 02:08 PM
Flat 6's make great tables. Keep up the good work.
Old 08-06-2014, 02:49 PM
Can I stack the cylinder to case gaskets?
My stock was 0.25mm, I see from my notes I had to remove 0.4mm from the heads, so I should have a 0.65mm gasket. Or can I use the 0.5mm gasket?
Old 08-07-2014, 11:34 AM
cams arrived today :
What goes where? Port and starboard?
Old 08-09-2014, 01:47 AM
JmuRiz's Avatar
4 bearing cams in a 2.7?
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 08-11-2014, 09:21 AM
the 4th bearing will just spin in free air
Old 08-28-2014, 02:21 PM
So finally I got 5 of 6 cylinder base gaskets....
Installed on p/c to find out that stock rod pins are to long for JE pistons, argh
Old 08-28-2014, 02:23 PM
Forgot to update here
P/C installed with supertec headstuds
Old 10-26-2014, 03:13 PM
Cam timing, took some time and some tries ended up with
cyl1-2-3 3.89mm
cyl4-5-6 3.81mm that was as close to 3.8mm I could get on the DC-30 camshafts
Old 10-26-2014, 03:16 PM
The dial goes backwards from 0, so this is at 3.89mm
RSR rocker arm seals
Old 10-26-2014, 03:17 PM
Made myself a camshaft tool
Old 11-06-2014, 02:29 PM
So I bought the camshaft oil restrictors, and after reading much for/against I decided to drill it somewhere inbetween.
From left stock - drilled - restrictor
Old 11-06-2014, 02:30 PM
Then I looked into the camshaft housing, and dooh there is a much smaller hole than the stock 6mm, I'll measure it tomorrow, but anything bigger than that up to stock hole is meaningless then...
I drilled mine 3.5mm, but if that is bigger than what's in the camshaft housing than it's the same if it's 3.5 or 6mm...
Old 11-06-2014, 02:32 PM
911 tweaks's Avatar
u r correct on all that u say here...but... keep in mind the entire oil circuit when using the later "restricted/smaller hole" fitting has increased overall system oil pressure which is another gain from using the smaller hole fitting...the other gain - debated by many - when using the restricted/smaller hole fitting, less oil is on top of the motor = better oil scavenging by the oil pump as there is more oil down in the sump that can be scavenged & a bit less fluctuation in the qty of oil in the oil tank...
I live for 911 tweaks...
Old 11-07-2014, 04:18 AM
