Life moves pretty fast.
I've got to the part in my 3.5 rebuild where it's time to fit the head studs.
I have bought ARP ones (nice box) and looking on this site there seems to be a lot of contradicting information as to how to fit them. Do I glue them in with Loctite like the originals ? These studs have a "nose" on the end, what is the installed height ? I asked ARP these questions and they said look at the instructions on the back of the box, what instructions
Twin plugging, you know it makes sense
E-85 sippin drunk
I was told DO NOT locktite the ARP headstuds in.... the tech guy at ARP advised to use the same moly lube that came with the studs that you use on the top of the studs, washers, and nuts. So, put the lube on the threads that go into the case as well. I did this on my watercooled VW and have had no problems. When I was putting my 930 motor back together, I called ARP, and they advised the same for both sides of the studs. Make sure that all the studs are inserted into the case the same length. Hope this helps.... I would call ARP tech reps just to confirm..... for your own reassurance... Brad
bty, the instructions should be on the cardboard outer sleeve of the box...
Brad...930 gt-1 racecar, increased displacement to 3.6L, JB racing Cylinders, JE 8 to1 pistons, stroked crank, Carrillo rods, extrudehoned 3.2L intake, full bay Bell I/C, GT-2 EVO cams, Rarly8 headers, GTX-3584RS turbo, twin plug, P&P heads, Link G4 EFi system, G-50/50 with LTD slip and oil squirters/oil cooler, zork tube, full race coilover system, with carbon fiber body, full cage, E-85 sippin drunk |
Banned
Re: ARP head studs
Constitutional Liberal
I have been reading about ARP head studs coming loose.
I think Steve commented on this problem. I used Supertec head studs on my 375 hp 3.5 Turbo and they have stayed in place for over 18K without retorquing. They (Sup) are installed using blue Loctite in the case and anti seize on the nut. They are designed differently but I wonder if loctite may cure the ARP loosening problem?
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Banned
The factory studs (latest divalar) come with a locking compound already on the stud.,Candy.
I can't imagine why there would be a problem using locktite to hold these studs in. Also can't imagine why you'd put assembly lube on the end that goes into the case. There should be a measured depth to install these to. You could do a trial assembly of one cylinder and head to see how deep to install them and get the right amount of thread for the nuts. Just be sure that they aren't bottomed out like Candy says.
-Andy
72 Carrera RS replica, Spec 911 racer |
E-85 sippin drunk
A clarification is needed. ![]() The ARP studs never loosened from the case as long as they were installed properly. The head NUTS were the ones that loosened up and in a few cases; backed up almost all the way off the threads. One well known engine builder suggested to me that I failed to torque them properly and I told that fine gentleman that not only di I know hoe to use these tools, but our torque wrenches are checked & recalibrated at least once a year. We use Snap-On split-beam models as well as the new electronic ones... ![]() Hope this helps,
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Hi Steve
I believe proper installation of ARP head studs is what this thread is about. It was not my intention to put words in your mouth. I was just trying to add something of value to the conversation. Referencing an expert incorrectly was not what I set out to do. What fool questioned your expertise? I for one believe that you have the required knowledge to operate a torque wrench properly. ![]() Don't you think that anti seize on any tread could promote loosening? Do you use Loctite on the case end? Why do you think the ARP studs are coming loose?
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell Last edited by Turbo_pro; 04-25-2007 at 07:14 AM.. |
No worries, mate. ![]() It would be inappropriate to name the party that suggested my inability to use a torque wrench on a public forum, even though the other party did just that,... ![]() I have never used nor needed anti-seize on head studs, but I do use Loctite to anchor the case ends. Since it releases very easily with heat, its not a problem at all. I use anti-seize (copper or nickel based) on fasteners living in harsh environments that will be disassembled from time to time. Exhaust systems are a perfect example as well as suspension hardware that anchor into aluminum alloys. Its my view that ARP head studs, while an excellent metallurgical product, do not accurately match the expansion rate of these engines very well and the head nuts loosen over time, especially with engines that operate at higher temps (930's, race motors, etc). I use steel studs on the little engines and 993TT/RSR Dilavars on everything else. Been doing this since 1993 with no issues whatsoever.
Steve, What defines a "little engine"?
Thank you!
Jon |
Well I got through to ARP's tech' department and this is their official installation procedure:-
Hand tighten them in, Use the supplied lube and torque to 38 ft/lb, You can use Loctite if you want but torque 'em' down before the Loctite sets. What about installed height ? No answer on this one. I was not over impressed by the quality of the advice, either they answer these questions every hour or they make it up as they go along. So I'm going to hand tighten them in, back them out to the correct length, use Loctite, torque 'em' down. and while I'm on here I did my own machining for twin plugging my heads, all worked out really well, didn't need to use any messy wax in the fins, I have a "patented" two bits of wood approach. If anyone is thinking of doing this I can advise and put some pics up. Cheers Pete
Sure like to see that.
Jon |
well as your interested.
I thought the sticking wax in the fins a really messy approach as I had just paid £90 to have the whole lot bead blasted. If this pic uploads OK, I made a clamp out of two bits of packing case backed with 1" x 1" steel box. Worked great, no vibration no broken fins.
Irrationally exuberant
Raceware head studs are also used without Loctite on the case ends.
-Chris
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
Try not, Do or Do not
I don't use ARP head studs but if they use 12 point nut instead of allen nuts (stock Porsche) then installed hieght has no meaning.
38 lbs ? That seems like a huge number. Not my product but I would have to ask how they came up with that number. I would only use that kind of torque on a 800 hp 1/4 mile motor.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
I used ARP studs on my rebuild. I carefully measured the stud height to arrive at a height where the 12 point nut was in the middle of the available thread. I found that the hieght was correct when measuring to the top of the thread, before the taper on the rounded top. I still have less than 10,000 miles on my rebuild - but I plan on checking my head nut torque during regular valve adjustments.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
Just to keep the record straight. I'm not sure if I'm the Steve referred to, but I did recently post that maybe my ARP head studs were backing out. I now have all the studs out, and can say that most of them were firmly in place. None seemed to back out or be loose. Two were pulled -both on No. 1 cylinder exhaust & intake toward the front of the engine.
My memory is that the height is 135mm to the top of the threads. That's what they were when I removed them. 38 ft-lbs is the same torque value I got from ARP, too. I also asked them to send me the installation sheet for that kit. ARP moly lube on the top; nothing required on the bottom - but if a sealant is used ... torque before it sets. By the way, the hardware looks perfect after 30K miles and 5 years. Based on what Steve said, maybe I should go back to the new style dilavar. More choices . . .
Steve '89 Carrera 4 |
Loose nut bhind the wheel
I used blue locktite at the case and ARP lube at the top. Installed height of 135mm to the top of the threads also. Using the ARP washers the threads should be just at the top of the 12 point nut when you do final torque. I used factory torque specs on mine since I have a Mag case. I will retorque to factory specs at each valve adjustment.
Ed 1970 911S Targa 2.7RS MFI dual plug 10.5:1 1974 260Z SCCA ITS 1998 M3 |
