jungspike's Avatar
Angry Crappy Dyno Results on 3.4L Rebuild (Status Update)
I just came back from a dyno run on my 3.2 to 3.4 rebuild, which included 98mm Mahle pistons, GT2 cams, Bursch 1 5/8 ID headers, M & K muffler, Autothority MAF, Polished intakes, matched injectors, SW chip, aluminum pressure plate. Dyno gave me a very disappointing 196 rear wheel HP (SAE corrected). I was expecting about 40 HP higher. Of course the Fuel to Air Mixture was very high (about 15). My question is: Can all of this be corrected by getting a new chip to fix the fuel mixture? Or do I have bigger problems?
84 911 Targa 3.4L
Old 03-22-2014, 01:10 PM
I would contact Steve Wong. I understand that he can take direct data from a Dyno Jet when he is doing custom chips. It may be that your engine combination doesn't exactly suit one of his normal chips.
Old 03-22-2014, 01:41 PM
It is too lean. Get your chip adjusted or get your DME adjusted. Run premium gas; make sure yiur DME is set right; i think there is also a California smog wire you need to disconnect (use search, I can't remember the details); get your AFR into the 13 or 12.5 range at peak torque. You are way too lean. I think the DME may retard spark if it detects too much heat, too, so that could be a factor if you are so lean you are overheating the engine...not sure, it has been a few years since I had a Carrera.
You should get more out of that engine if you have everything set right.
Check plug gaps, too. And air filter, etc.
Good luck!
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 03-22-2014, 01:50 PM
Wer bremst verliert
JohnJL's Avatar
no results are bad, they tell you if you have a problem and help diagnose issues. you cannot compare results across dynos.
you are way too lean. did the dyno operator say anything? i wouldnt have kept doing any more runs and would not drive the car until you diagnose why you are soo lean. chech that other stuff emery said too. you want to ba about 12.7 - 13 under full load
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-23-2014, 10:22 AM
Wer bremst verliert
JohnJL's Avatar
who built the motor? sure the cam and ignition timing are right?
Old 03-23-2014, 10:26 AM
AlfonsoR's Avatar
Maybe my math is wrong, but the relative increase in displacement is close to the relative increase in HP, so it seems to me (from what I know) that the change is reasonable, considering that no major change was made to the induction system, i.e. no ITBs. Grant it, you probably have some room left on the table in regards to tuning.
Is this cam optimal for plenum induction?
"Simplicity is supreme excellence" - James Watt
Old 03-23-2014, 12:55 PM
Straight shooter
Lapkritis's Avatar
Agreed. That 15:1 would have me looking at a misfire perhaps. 13:1 is the target I use when tuning all motor air to fuel. When I look at your peak numbers vs. Rpm, I think you're leaving a lot on the table here. Generally when I see this and there is no misfire I think the fuel pressure regulator isn't matched to the chip/programming.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.”
― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values
Old 03-23-2014, 01:29 PM
Motronic tuning
The above thread has some detail about the CA wire and the DME settings you can make yourself. Be careful with changes - you do not want to introduce a scenario where you damage your engine, so take it slow.
You also should check your fuel delivery overall: plugged filter? Etc. For some reason you are lean.
It comes down to two dimensions: timing advance and fuel delivery in combination to get you where you want to be.
Emery
Old 03-23-2014, 04:17 PM
jungspike's Avatar
Thanks for all the advice.
Redcoupe: I sent an email to Steve. I’m starting to think that I have another problem, that once fixed will allow my chip to work fine. I found this thread very helpful in addition to the one Emery suggested:
DME Motronic - O2 sensor questions
Emery: I checked for a vacuum leak using a can of carb cleaner and found none. I inspected the air filter and cleaned it. It did not appear clogged or damaged.
Overheating? I do not know what the cylinder head temp is reading (could be part of the problem), but the oil temp gauge is reading in the low normal range.
JohnJL: I did 3 runs--all with very similar results. Dyno Guy offered to do more runs, but I did not want to because (as you stated) fear of doing damage. I didn’t come prepared for tuning. If I did I would had put on the stock “flapper” mass flow sensor and seen if the Autothority MAF is the problem.
As for who built it? I’ll leave his name out of it for now. I do not want to give him bad press before he has a chance to fix it… but he is a very reputable builder, does lots of race cars, hill climb cars and has worked with people such as Alois Ruf. My plan is to take it back to him and ask some questions based on all of the Pelican’s advice.
AlfonsoR: Yes you are right the HP is not that bad. Assuming I was at 207 BHP when I started. The pistons should have brought me to 207 x 3.4/3.2 = 220 HP, then accounting for 15% drive train loss, it would bring me back to 187 RWHP, which is close to the 196 that I got. I just think with the cams, intake and headers, I would be closer to 220 RWHP. The guy did the run in 4th gear. Is that normal? So, to your point (and JohnJL “there is not bad dyno results”)… the problem is NOT the HP, but the mixture.
Lapkritis: Misfire? Would I hear it? It sounds great.
One other symptom, which might be related is that sometimes it will not idle and shifts to 2,000 RPMs (high idle?) and sometimes to 1,100 RPMs.
Bottom line: I’ll take it back and have them check the plugs, fuel pressure and cam/ignition timing.
Thanks for all your help. I’ll let you know what I figure out.
Tim
84 911 Targa 3.4L
Old 03-23-2014, 07:04 PM
KTL KTL is offline
Schleprock
KTL's Avatar
Problem with the chip tuning is that it's not the typical type of tuning done for the engine. This is because of the Autothority MAF system you have installed. I'd consider getting a baselined 3.4L chip from SW, and install the old standby barn door air flow meter. SW knows the deal with the Autothority MAF. But I suspect you'd be better off with the original system because he's done MUCH more development & tuning on cars with the original system.
Kevin L
'86 Carrera "Larry"
Old 03-24-2014, 10:50 AM
safe's Avatar
Way too lean.
13:1 maybe down to 12-12.5:1 to get the most power.
I think you should be close to 220 rwhp.
Magnus
Old 03-24-2014, 11:59 AM
jungspike's Avatar
Kevin,
I agree with what you are saying... I have never been impressed with that Autothority thing. I would have been horrified if I paid full price for it. One thing that makes me think it is OK: Before I did all the internal engine mods, I put in the chip, the intakes and the MAF. I passed emmisions testing... but of course that wasn't under Wide Open Throttle.
Tomorrow, the shop is going to look at it. If they can't find a fuel pressure or a timing issue, I'll go back to the flapper door sensor.
Tim
84 911 Targa 3.4L
Old 03-24-2014, 12:17 PM
PFM PFM is offline
PFM
PFM's Avatar
Tim,
What fuel were you running? Did it have any alcohol content? As the motor was super lean near PK TQ it is possible you ran it out of injector. Do you know what fuel pressure you have? Can you monitor it on the dyno? I would be checking spark plugs if you made 3 pulls at 15 to one. I would suggest you have the dyno operator NOT continue any pulls that go leaner than 14.2 at or around PK TQ.
Good luck. Please let us know what you find.
Stay Tuned,
PFM
Old 03-24-2014, 08:10 PM
jungspike's Avatar
That is a good observation PFM (that max lean correlates to peak torque, thus injectors might be maxed out). Fuel had 10% Ethanol (yuk!).
I'm taking it back to the shop tomorrow and will have them check fuel pressure and pull the plugs. I'll get a pressure gauge to tap into fuel rails for MY next dyno. Should be a simple tool I can get from our Host?
SW informed me the chip was created from some air flow data he received via phone... so, although I probably have some other hardware issues (fuel pressure), eventually I'll need a new chip.
84 911 Targa 3.4L
Old 03-24-2014, 09:15 PM
304065's Avatar
Stochiometric of E10 is richer than gasoline, around 14.1. So this exacerbates the lean issues more.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 03-25-2014, 07:27 AM
jungspike's Avatar
Its back at the builder, now. He thinks it is a fuel pressure problem. He is also going to swap out the chip since that chip was made for a special/unusual engine. When I go back to the dyno, I'll bring my stock flapper valve to swap it out if required. I'm also planning on using ethanol-free racing fuel. She should be on the dyno in a week.
Thanks for the help Pelicans,
I'll let you know how it turns out,
Tim
84 911 Targa 3.4L
Old 03-25-2014, 07:24 PM
PFM PFM is offline
PFM
PFM's Avatar
Tim,
I am glad the builder is looking at fuel pressure. I questioned the alcohol only because it takes even MORE injector to handle that. What injectors do you have? I maxed out my 3.6 injectors on a 3.1 at 5500 RPM before I moved to E85. You did increase the motor size and the required fuel.
Good luck.
Stay Tuned,
PFM
Old 03-25-2014, 08:06 PM
jungspike's Avatar
Injectors? I pretty sure they are stock, but I'll check. Builder did say they were "matched." I didn't think that they could be the weakest link in my fuel delivery. What type of injectors do you recommend? I didn't see any any from our Host or a quick Google search, but I'll keep looking.
Tim
84 911 Targa 3.4L
Old 03-25-2014, 08:57 PM
I would question the builder about cam timing, and ask for a recheck. Did you remove the O2 sensor and put the probe into the hole for the O2 sensor to check the AF ratio at wide open throttle? If the readings are at the tailpipe, and you have a CAT, then you are not "way too lean". Also, lean mixtures that do not misfire usually give more HP. Your curve seems pretty smooth to me, not indicating a way too lean condition. Note that at peak power, your AF ratio is about 13.5 which is pretty close to ideal. So, if the readings were at the tailpipe with the cat in place, you are probably rich.
Old 03-26-2014, 04:09 PM
jungspike's Avatar
Steve,
I do not have a cat. I have headers (with an O2 sensor) and M&K muffler. Air-to-Fuel readings were taken at the tailpipe. Builder is checking cam timing. Yes, at 6,000 RPMs the mixture is reasonable, but my first concerned about the 4 to 5,000 range where it is very high. I'm concerned about engine damage. However, you are correct--this will not effect the relatively low HP at 6,000 RPMs.
Thanks,
Tim
84 911 Targa 3.4L
Old 03-26-2014, 04:58 PM
