-   -   Another 930 Engine Conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/819630-another-930-engine-conversion.html)
930/66 07-10-2014 09:05 AM
Removing some Parts
http://forums.pelicanparts.com/uploa...1405008182.jpg
http://forums.pelicanparts.com/uploa...1405008206.jpg
http://forums.pelicanparts.com/uploa...1405008222.jpg
http://forums.pelicanparts.com/uploa...1405008238.jpg
http://forums.pelicanparts.com/uploa...1405008257.jpg
http://forums.pelicanparts.com/uploa...1405008283.jpg
930/66 07-13-2014 04:25 AM
Preparing Parts for Powder Coating
many of the parts are rusty and some rubber sealing are broken
http://forums.pelicanparts.com/uploa...1405250593.jpg
http://forums.pelicanparts.com/uploa...1405250620.jpg
http://forums.pelicanparts.com/uploa...1405250643.jpg
http://forums.pelicanparts.com/uploa...1405250662.jpg
http://forums.pelicanparts.com/uploa...1405250673.jpg
http://forums.pelicanparts.com/uploa...1405250691.jpg
http://forums.pelicanparts.com/uploa...1405250732.jpg
930/66 07-13-2014 04:45 AM
Disassembling Cylider Heads for Porting and Replacing Valve Guides
http://forums.pelicanparts.com/uploa...1405251764.jpg
http://forums.pelicanparts.com/uploa...1405251778.jpg
http://forums.pelicanparts.com/uploa...1405251812.jpg
http://forums.pelicanparts.com/uploa...1405251830.jpg
http://forums.pelicanparts.com/uploa...1405251849.jpg
http://forums.pelicanparts.com/uploa...1405251865.jpg
http://forums.pelicanparts.com/uploa...1405251878.jpg
http://forums.pelicanparts.com/uploa...1405251893.jpg
http://forums.pelicanparts.com/uploa...1405251917.jpg
http://forums.pelicanparts.com/uploa...1405251936.jpg
930/66 07-13-2014 05:24 AM
Disassembling Intake Manifold
http://forums.pelicanparts.com/uploa...1405254078.jpg
http://forums.pelicanparts.com/uploa...1405254108.jpg
http://forums.pelicanparts.com/uploa...1405254120.jpg
http://forums.pelicanparts.com/uploa...1405254133.jpg
http://forums.pelicanparts.com/uploa...1405254151.jpg
http://forums.pelicanparts.com/uploa...1405254171.jpg
http://forums.pelicanparts.com/uploa...1405254183.jpg
http://forums.pelicanparts.com/uploa...1405254205.jpg
looks bad
http://forums.pelicanparts.com/uploa...1405254218.jpg
930/66 07-13-2014 06:59 AM
Porting Cylinder Heads
before i bring the cylinder heads to the shop (for replacing the valve guides) i porting the Heads myself.
Intake to 36mm
Exhaust to 38mm
930/66 07-13-2014 07:09 AM
Intake 32 to 36mm
http://forums.pelicanparts.com/uploa...1405260482.jpg
http://forums.pelicanparts.com/uploa...1405260498.jpg
http://forums.pelicanparts.com/uploa...1405260511.jpg
http://forums.pelicanparts.com/uploa...1405260521.jpg
http://forums.pelicanparts.com/uploa...1405260536.jpg
http://forums.pelicanparts.com/uploa...1405260549.jpg
930/66 07-13-2014 07:12 AM
Exhaust to 38mm
http://forums.pelicanparts.com/uploa...1405260662.jpg
http://forums.pelicanparts.com/uploa...1405260673.jpg
http://forums.pelicanparts.com/uploa...1405260683.jpg
http://forums.pelicanparts.com/uploa...1405260721.jpg
http://forums.pelicanparts.com/uploa...1405260732.jpg
http://forums.pelicanparts.com/uploa...1405260745.jpg
930/66 07-13-2014 07:37 AM
Intake Manifold ported to 36mm
all with a milling cutter
http://forums.pelicanparts.com/uploa...1405262213.jpg
http://forums.pelicanparts.com/uploa...1405262233.jpg
http://forums.pelicanparts.com/uploa...1405262248.jpg
http://forums.pelicanparts.com/uploa...1405262261.jpg
A&F 07-13-2014 09:30 AM
Awesome Project!
930/66 07-16-2014 11:15 AM
Some Parts have arrived by Post
I have many parts from Pelikan Members...Thank You!!!
The Mahle 3.4L full finned Pistons and Cylinders (used) come from tomdeq he converted his 930 back to stock.
The Camshafts 964 with no wear / pitting are from Anastasios also used Parts.
http://forums.pelicanparts.com/uploa...1405534375.jpg
http://forums.pelicanparts.com/uploa...1405534398.jpg
http://forums.pelicanparts.com/uploa...1405534412.jpg
http://forums.pelicanparts.com/uploa...1405534432.jpg
http://forums.pelicanparts.com/uploa...1405534442.jpg
http://forums.pelicanparts.com/uploa...1405534464.jpg
http://forums.pelicanparts.com/uploa...1405534475.jpg
http://forums.pelicanparts.com/uploa...1405534491.jpg
930/66 07-16-2014 12:49 PM
964 Camshaft
I had to modify the camshaft for the 930.
left: extender for scavenge pump
right: remove power steering pump adapter
http://forums.pelicanparts.com/uploa...1405540057.jpg
http://forums.pelicanparts.com/uploa...1405540069.jpg
http://forums.pelicanparts.com/uploa...1405540086.jpg
http://forums.pelicanparts.com/uploa...1405540103.jpg
http://forums.pelicanparts.com/uploa...1405540124.jpg
http://forums.pelicanparts.com/uploa...1405540146.jpg
http://forums.pelicanparts.com/uploa...1405540164.jpg
930/66 07-16-2014 01:01 PM
P/C Mahle 3.4 7:5:1
general condition is good
2 piston rings and 1 oil scraper ring were broken, it was not easy to get new one`s.
there are 2 different versions of the 3.4 liter set.
only RUF in Germany had new one.
I modified the cylinder (old school know how)
http://forums.pelicanparts.com/uploa...1405540869.jpg
http://forums.pelicanparts.com/uploa...1405540878.jpg
http://forums.pelicanparts.com/uploa...1405540888.jpg
http://forums.pelicanparts.com/uploa...1405540896.jpg
proffighter 07-16-2014 03:47 PM
1000 pics and not even close to re-assembly:D
Nice, go on buddy!
930/66 07-21-2014 12:22 PM
Nice, go on buddy!
:) I know I'm not the man of 1000 words but with 1000 pics
930/66 07-21-2014 12:27 PM
Splitting the Crankcase
http://forums.pelicanparts.com/uploa...1405970723.jpg
http://forums.pelicanparts.com/uploa...1405970756.jpg
http://forums.pelicanparts.com/uploa...1405970775.jpg
http://forums.pelicanparts.com/uploa...1405970805.jpg
http://forums.pelicanparts.com/uploa...1405970819.jpg
930/66 07-21-2014 12:36 PM
Bearing Shell Main Bearings / Intermedia Shaft
Looks not to bad:
http://forums.pelicanparts.com/uploa...1405971320.jpg
http://forums.pelicanparts.com/uploa...1405971328.jpg
http://forums.pelicanparts.com/uploa...1405971340.jpg
http://forums.pelicanparts.com/uploa...1405971353.jpg
http://forums.pelicanparts.com/uploa...1405971367.jpg
http://forums.pelicanparts.com/uploa...1405971378.jpg
http://forums.pelicanparts.com/uploa...1405971391.jpg
http://forums.pelicanparts.com/uploa...1405971406.jpg
jsveb 07-21-2014 10:01 PM
Please tell why you made the cut-outs in the cylinders.
I know why we did it on two-stroke engines, but gather this is not the same.
proffighter 07-22-2014 04:44 AM
That's a classic tuning procedure (boattailing) to relieve gas exchange or breathing between the cylinders and the crankcase (volume below the piston). According Bruce Anderson 10 more hp for a 2 liter engine. This needs also machining the crankcase like this which correspond (red) to the slots in the cylinders:
http://forums.pelicanparts.com/uploa...1406028716.jpg
http://forums.pelicanparts.com/uploa...1406029359.jpg
I do not have seen any dyno to proof, but because I don't see any downside except the work it's worth a try
930/66 07-22-2014 10:21 AM
Thank you Roland for the illustration!
I have picture from the Bruce Anderson Book (German Version from Roland)
This modification was made at all the factory 2 liter racing engines.
http://forums.pelicanparts.com/uploa...1406049668.jpg
http://forums.pelicanparts.com/uploa...1406049682.jpg
http://forums.pelicanparts.com/uploa...1406049694.jpg
http://forums.pelicanparts.com/uploa...1406049707.jpg
930/66 07-22-2014 10:52 AM
Disassembling Crankshaft
The bearings and surfaces are in good condition.http://forums.pelicanparts.com/uploa...1406051441.jpg
http://forums.pelicanparts.com/uploa...1406051455.jpg
http://forums.pelicanparts.com/uploa...1406051465.jpg
http://forums.pelicanparts.com/uploa...1406051488.jpg
http://forums.pelicanparts.com/uploa...1406051511.jpg
http://forums.pelicanparts.com/uploa...1406051522.jpg
