-   -   Another 930 Engine Conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/819630-another-930-engine-conversion.html)
930/66 08-09-2014 01:57 AM
Assembling Oil Temperature Regulator
http://forums.pelicanparts.com/uploa...1407574612.jpg
http://forums.pelicanparts.com/uploa...1407574624.jpg
930/66 08-09-2014 02:02 AM
Vent Cover
http://forums.pelicanparts.com/uploa...1407574898.jpg
http://forums.pelicanparts.com/uploa...1407574910.jpg
http://forums.pelicanparts.com/uploa...1407574930.jpg
http://forums.pelicanparts.com/uploa...1407574950.jpg
930/66 08-09-2014 02:06 AM
Assembling New Turbocharger Oil Feed Line Set from TurboKraft
http://forums.pelicanparts.com/uploa...1407575157.jpg
http://forums.pelicanparts.com/uploa...1407575168.jpg
http://forums.pelicanparts.com/uploa...1407575191.jpg
930/66 08-09-2014 02:52 AM
Installing Air Guide Plates
http://forums.pelicanparts.com/uploa...1407577923.jpg
http://forums.pelicanparts.com/uploa...1407577935.jpg
http://forums.pelicanparts.com/uploa...1407577951.jpg
http://forums.pelicanparts.com/uploa...1407577963.jpg
930/66 08-09-2014 02:55 AM
Assembling Zylinder Heads
http://forums.pelicanparts.com/uploa...1407578045.jpg
http://forums.pelicanparts.com/uploa...1407578058.jpg
http://forums.pelicanparts.com/uploa...1407578072.jpg
http://forums.pelicanparts.com/uploa...1407578079.jpg
http://forums.pelicanparts.com/uploa...1407578097.jpg
http://forums.pelicanparts.com/uploa...1407578114.jpg
http://forums.pelicanparts.com/uploa...1407578132.jpg
http://forums.pelicanparts.com/uploa...1407578145.jpg
930/66 08-09-2014 03:00 AM
Assembling Zylinder Heads and Camshaft Housing
http://forums.pelicanparts.com/uploa...1407578363.jpg
http://forums.pelicanparts.com/uploa...1407578390.jpg
http://forums.pelicanparts.com/uploa...1407578408.jpg
http://forums.pelicanparts.com/uploa...1407578425.jpg
http://forums.pelicanparts.com/uploa...1407578440.jpg
http://forums.pelicanparts.com/uploa...1407578451.jpg
930/66 08-10-2014 02:53 AM
Preparation Chain Housing / Assembling
Befor Assembling the Chain Housing i have to preparation it.
The Sealing Kit from Supertec has everything you need!
http://forums.pelicanparts.com/uploa...1407664235.jpg
http://forums.pelicanparts.com/uploa...1407664259.jpg
http://forums.pelicanparts.com/uploa...1407664271.jpg
http://forums.pelicanparts.com/uploa...1407664291.jpg
http://forums.pelicanparts.com/uploa...1407664311.jpg
http://forums.pelicanparts.com/uploa...1407664329.jpg
http://forums.pelicanparts.com/uploa...1407664343.jpg
http://forums.pelicanparts.com/uploa...1407664370.jpg
http://forums.pelicanparts.com/uploa...1407664396.jpg
930/66 08-10-2014 02:56 AM
Assembling 964 Camshaft and End Cover
http://forums.pelicanparts.com/uploa...1407664548.jpg
http://forums.pelicanparts.com/uploa...1407664562.jpg
http://forums.pelicanparts.com/uploa...1407664571.jpg
http://forums.pelicanparts.com/uploa...1407664582.jpg
930/66 08-10-2014 02:58 AM
Installing Camshaft Sprocket
http://forums.pelicanparts.com/uploa...1407664667.jpg
http://forums.pelicanparts.com/uploa...1407664677.jpg
http://forums.pelicanparts.com/uploa...1407664686.jpg
930/66 08-10-2014 03:09 AM
Installing Patrick Motorsport RSR Flyweel
http://forums.pelicanparts.com/uploa...1407665302.jpg
http://forums.pelicanparts.com/uploa...1407665313.jpg
http://forums.pelicanparts.com/uploa...1407665326.jpg
http://forums.pelicanparts.com/uploa...1407665338.jpg
930/66 08-10-2014 03:11 AM
Installing D-Zug Pulley
http://forums.pelicanparts.com/uploa...1407665472.jpg
http://forums.pelicanparts.com/uploa...1407665454.jpg
http://forums.pelicanparts.com/uploa...1407665500.jpg
930/66 08-10-2014 03:15 AM
Checking Parallel of Sprockets with Stromski Racing Tool
I Think for a DIY is the Tool from Stromski Racing helpful
http://forums.pelicanparts.com/uploa...1407665702.jpg
http://forums.pelicanparts.com/uploa...1407665718.jpg
http://forums.pelicanparts.com/uploa...1407665729.jpg
930/66 08-10-2014 03:27 AM
Installing End Cover for Intermedia Shaft
http://forums.pelicanparts.com/uploa...1407666393.jpg
http://forums.pelicanparts.com/uploa...1407666419.jpg
http://forums.pelicanparts.com/uploa...1407666430.jpg
930/66 08-10-2014 03:33 AM
Installing Chain on Sprockets an fix it with the Chain Sprocket Holder
http://forums.pelicanparts.com/uploa...1407666750.jpg
http://forums.pelicanparts.com/uploa...1407666770.jpg
http://forums.pelicanparts.com/uploa...1407666784.jpg
rennch 08-12-2014 01:52 AM
It's on my bucket list to rebuild a Porsche engine. This seems so complicated, and beautiful at the same time. Fantastic job.
gsxrken 08-12-2014 01:31 PM
Great attention to detail on the build, and well-lit photography.
I remember when those 3.4 cylinders came up for sale and I started daydreaming about picking them up. Glad they went to such a fine home!
Ken
930/66 08-14-2014 01:26 PM
the conversation from 3.3 to 3.4 was many jears in my Head!
930/66 08-14-2014 01:33 PM
Ken
Hi Ken
Thanks for your kind words!
930/66 08-16-2014 09:39 AM
Installing Rocker Arm with new Rocker Arm Shaft
Installing Rocker Arm (with new bushings) and new Rocker Arm Shaft.
I also ordered the Rocker Shaft Lock Set and the Rocker Shaft Seal Set : Porsche Motorsport from Chris TurboKraft.
Bolts from the Rocker Shaft and some Adjusting screw and nuts are also new.
http://forums.pelicanparts.com/uploa...1408207101.jpg
http://forums.pelicanparts.com/uploa...1408207132.jpg
http://forums.pelicanparts.com/uploa...1408207146.jpg
http://forums.pelicanparts.com/uploa...1408207157.jpg
http://forums.pelicanparts.com/uploa...1408207168.jpg
http://forums.pelicanparts.com/uploa...1408207183.jpg
930/66 08-16-2014 09:49 AM
Assembling Rocker Arms in the Camshaft Housing
http://forums.pelicanparts.com/uploa...1408207710.jpg
http://forums.pelicanparts.com/uploa...1408207720.jpg
http://forums.pelicanparts.com/uploa...1408207728.jpg
http://forums.pelicanparts.com/uploa...1408207735.jpg
http://forums.pelicanparts.com/uploa...1408207746.jpg
