LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
930/66's Avatar
Installing Fuel Pressure Diaphragm Damper
87 930 3.4, BW EFR 7670, TK Long Neck IC, Fabspeed Headers, 964 NW`s, Ported Heads, Tial F46 (0.4Bar Spring), Turbosmart EBC, BL WUR with rpm switch /solenoid, SDS CPI Ignition, modified Muffler, and many other little mods
Old 02-21-2015, 07:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
930/66's Avatar
Installing New Fuel Pressure Regulator
Installing New Fuel Pressure Regulator:
The old Regulater had only 2 washers installed (0.8 mm) System pressure 6.0 Bar:
New:
New has 3 washers installed (1.4mm):
Old 02-21-2015, 07:54 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
930/66's Avatar
Check Fuel Pump Delivery Rate
First I Check the Fuel delivery Rate: Setpoint / min:1500cc / 30Sek. (both pump)
Actual Values: 1500cc after 22 Sek
Second Test: Delivery Rate from the Systempressure circuit: Setpoint 160-240cc/min
Actual Values: 280cc/min (98 oct) 461g-249g = 212g : 0.755 = 280cc
Old 02-22-2015, 06:39 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
930/66's Avatar
CIS Injector Testing
I did a injector test.
1. Injection flow pattern was ok
2. Spray 4 from 6 not similar (not atomizing correctly)
3. Drip or leak test ok
4. Delivery Rate ok 2.5% Difference
I have Order 6 New 009 Injectors, than i make the Test Again.
Old 02-22-2015, 07:13 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
proffighter's Avatar
Nice attention on every detail. I wonder how equal spray pattern on new injectors is!
Roland
930 Turbo '81 Too many modifications to list
Old 02-22-2015, 10:44 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
930/66's Avatar
Hi Roland
We will see how equal there will be!
Old 02-23-2015, 10:01 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
930/66's Avatar
The Order arrived Today, 6 New 009 Injectors
Tomorrow they will be tested....
Old 02-23-2015, 10:04 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
930/66's Avatar
Second CIS Injector Test with New 009
I did a injector test again with the new injectors.
1. Injection flow pattern was perfect
2. Spray all 6 absolut similar (atomizing perfect)
4. Delivery Rate ok 2.035% Difference
Flow Rate with the old 009 Injectors vs new (Factor 0.755 98Okt)
Engine 930.66 / Fuel Head Nr. 0438100037 / WUR Nr. 0438140112 / Injectors Nr. 0437502009
System Pressure setpoints: 6.00 to 6.70 Bar (between 6.20 and 6.40Bar)
System Pressure actual values: 6.30 Bar (12.2V)
Contol Pressure cold setpoints: 1.20Bar (Temperatur 20°C)
Contol Pressure cold actual values: 1.20 Bar
Contol Pressure warm setpoints: 3.65 Bar (+/- 0.20 Bar)
Contol Pressure warm actual values: 3.20 Bar
Full throttle enrichment setpoints: 2.90 Bar (+/- 0.20 Bar)
Full throttle enrichment actual values 2.60 Bar
Delivery Rate in 30 seconds old Injectors (Full without Full enrichment):
Old: vs New:
Cylinder 1 176cc 184cc
Cylinder 2 177cc 179cc
Cylinder 3 180cc 179cc
Cylinder 4 179cc 176cc
Cylinder 5 184cc 180cc
Cylinder 6 182cc 184cc
Old 02-26-2015, 11:17 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
930/66's Avatar
Adjusting individual Injector Flow on Fuel Distributor
Goal: Adjusting individual Injector Flow on Fuel Distributor
After my engine revision / conversion (1500 miles even driven) the engine outlet sees like this: Cyl. 2 and 5 looks similar leaner than 1/3/4/6
I removed the cap from the Fuel Distributor, under that cap is the adjustment screw for each cylinder (differential pressure adjustment / turning the allen head flow adjuster clockwise increases the Fuel):
I have the settings adjusted 5 times and that`s the new data:
Delivery Rate in 30 seconds new Injectors (Full without Full enrichment):
New: vs New (adjusted):
Cylinder 1 184cc 181cc (old 176cc)
Cylinder 2 179cc 187cc (old 177cc)
Cylinder 3 179cc 179cc (old 180cc)
Cylinder 4 176cc 178cc (old 179cc)
Cylinder 5 180cc 186cc (old 184cc)
Cylinder 6 184cc 183cc (old 182cc)
Old 02-26-2015, 11:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
Thomas
So is this what you leave or just one first try and what's the desired goal?
Looks still a bit too much difference, 8cc or about 5%
Try once more little Padawan
Roland
Old 02-27-2015, 03:12 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
930/66's Avatar
Thomas
Roland
This is at the moment my Final Adjusting the goal was more Fuel for Cyl. 2 and 5.
Cyl 2 and 5 are all the time leaner as the others than makes not sense to adjusting all Cyl to similar amount.
The Value for the other Cyl 1/3/4/6 has changed positiv with the new Injectors vs old (just cyl 4 has 1cc less than before but he was not to lean.
Cylinder 1 184cc 181cc (old 176cc) 5cc more as before
Cylinder 2 179cc 187cc (old 177cc) 10cc more as before
Cylinder 3 179cc 179cc (old 180cc) 1cc more as before
Cylinder 4 176cc 178cc (old 179cc) 1cc less as before
Cylinder 5 180cc 186cc (old 184cc) 2cc more as before
Cylinder 6 184cc 183cc (old 182cc) 1cc more as before
Old 02-27-2015, 07:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
930/66's Avatar
Roland here is a picture from the Header here you can see what i mean.
Old 02-27-2015, 07:40 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
So we can't wait to see how the headers/heads will look after a while of driving. I am curious how much difference it needs to get them equal in color/ AFR
Roland
Old 02-27-2015, 10:47 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
Nice work!
Old 02-27-2015, 12:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
930/66's Avatar
Here is a good topic:
cylinders 2 and 5 lean
Old 02-28-2015, 04:06 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
930/66's Avatar
Testdrive to lean at Top End
After I set the WUR richer (Full throttle enrichment) i made a Testdrive:
I`m to lean at the Top End:
Now i go another Way...i have ordered a BL WUR with the RPM CSV Kit
Old 03-22-2015, 03:05 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
930/66's Avatar
Brian Leask WUR and RPM CSV Kit
I`m happy now... I`m a proud owner from a Brian Leask WUR and RPM CSV Kit
Now, I just have to install the part...but first I have to fix a problem with my Cayenne S
Old 05-04-2015, 10:35 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
930/66's Avatar
AFR Values with BLWUR
Much time has passed but now i have some results.
The AFR values are much better, i have just a little bit to optimize.
The picture shows the values of a dyno run:
Old 09-13-2015, 06:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
930/66's Avatar
Dyno Sheet
Values are with 0.9 Bar Spring and measured at the crank.
452.7 PS and 423ft/lbs
There are 2 different measurements on the Dyno Sheet. The Difference are two different KKK`s K27/7200 and K27/29 Hybrid
Old 09-13-2015, 06:50 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
Hi 930/66,
It's been almost a year since any updates on this. Very nice build. I have one question. From looking at the pics in post 107 pg 6 it looks like you mounted the Bosch WBO2 in the driver side bank secondary pre-turbo? There are typically two problems when doing this, the wide band won't last at pre-turbo temps (unless you go to an NTK) and the AFR readings are skewed to the rich side since the sensor output is affected by back pressure in the header. As the back-pressure increases, the AFR gauge reads less than actual so if the AFR is reading 12.5 the actual AFR will be leaner, not desirable. Just wondering how that location has worked out?. With EFI a compensation table is normally used that adjusts the WBO2 output based on back pressure, not possible with CIS. Have you had any problems? I have a build in mind that will require two WBO2 pre-turbo but it will be EFI.
Old 08-27-2016, 09:43 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
