wacko's Avatar
Headstud washers?
Hello all,
I need to pick up a couple headstud washers locally. Is there anything unique about them or can I just match up the size?
Old 11-06-2014, 01:16 PM
They're thicker than washers meant for general use, and flatter, as well. Get the right ones and be done with it.
The Cap'n
Old 11-06-2014, 03:58 PM
They're also made of hardened forged steel.. not stamped out pot metal.
Old 11-06-2014, 05:02 PM
Walt Fricke's Avatar
Short answer - you can't pick them up locally from a hardware store. A Porsche dealer (though nowadays they'd probably have to order), or a shop which works on Porsches (may have some used ones sitting around - used is just fine). If you happen to live next door to Maryland Metric or some specialty fastener place, maybe they'd have these, but I don't think they are in any way a standard washer. Others have noted features not found in normal washers. The thickness alone puts it in the special class.
Old 11-06-2014, 10:02 PM
I have freshly plated head stud washers.
PM me if interested.
Tom Butler
1973 RSR Clone
1970 911E
914-6 GT Recreation in Process
Old 11-07-2014, 02:50 AM
wacko's Avatar
I was able to find them locally. Same size and thickness, $0.70 each
Old 11-08-2014, 08:43 AM
Just curious and I know it's insignificant but if you rattle them around together in a small paper bag or box or drop them on a stone hard surface so they ring?
If they do they're probably forged steel like the ones Porsche used.
Old 11-08-2014, 09:30 AM
Jeff Alton's Avatar
We have a bunch of used ones in stock, just down the highway from you....
Cheers
www.turn3autosport.com
Old 11-09-2014, 06:25 PM
wacko's Avatar
Thanks Jeff, you were my next stop but I was able to find them in Chilliwack
Old 11-14-2014, 10:24 AM
