Hello, I been searching All around the world for a set of piston and cylinder for my engine, but apparently they are no longer in production. My engine is a 901/16 with a compression ratio of 8.6:1. My car is a 911 t manual karmann coupe from 1969. The pistons are diameter 80 mm. I have been offered pistons and cylinder set that have a compression ratio of 9.5:1. I observe that the shape of the piston is completely different, so I am concerned that it won't be compatible with my cylinder head. Can someone help me an give me some guidance with this. Thanks.
Hi,
The original iron cylinders, and even Biral ones are NLA; everything from Mahle is all Nikasil which is really a good thing. The main thing for you is making sure that your pistons are for the '65-'69 deep-chambered heads, NOT the '70-'73 shallow chamber ones. If you post a picture of the ones you've been offered, it will be much easier to ID them and tell you if they will work or not.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Could there be any problems with using Nikasil cylinders without having piston oil cooling?
I have 2.0T pistons and cylinders. PM me for details.
Tom Butler 1973 RSR Clone 1970 911E - Sold but Never Forgotten 914-6 GT Clone |
![]() ![]() this are my original pistons |
![]() These are the one that someone offered me |
Those pistons looks like they were made for the later (2.2-2.4) heads and will not fit your early ones without a lot of machine work (never a good idea).
hello Steve, thanks for the reply . the manufacturer ln engineering has taged this set as this "Porsche 911 914-6 2.0 80mm Nickies inc. 9.5:1 JE Piston set" do all of the cylinder heads of the 2.0 lt engines are the same or they are different depending the compression ratio? thanks.
what can you suggest me to do with my engine?
I could make a hundred suggestions, but everything depends on your budget, performance expectations, and how the car will be used. ![]() If you want detailed assistance, take a look at this: Performance Consulting | Rennsport Systems | Porsche Performance Systems and Support
Thanks for all the information. One last question, are this pistons more adequate?
Those are 2.0 P/C's and will work just fine with your 2.0 heads.
