Porsche Crest Rebuilding a 901/16 engine 2.0 1969
Hello, I been searching All around the world for a set of piston and cylinder for my engine, but apparently they are no longer in production. My engine is a 901/16 with a compression ratio of 8.6:1. My car is a 911 t manual karmann coupe from 1969. The pistons are diameter 80 mm. I have been offered pistons and cylinder set that have a compression ratio of 9.5:1. I observe that the shape of the piston is completely different, so I am concerned that it won't be compatible with my cylinder head. Can someone help me an give me some guidance with this. Thanks.
Old 12-04-2014, 06:18 PM
Hi,
The original iron cylinders, and even Biral ones are NLA; everything from Mahle is all Nikasil which is really a good thing.
The main thing for you is making sure that your pistons are for the '65-'69 deep-chambered heads, NOT the '70-'73 shallow chamber ones.
If you post a picture of the ones you've been offered, it will be much easier to ID them and tell you if they will work or not.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-04-2014, 07:52 PM
Could there be any problems with using Nikasil cylinders without having piston oil cooling?
Old 12-05-2014, 03:01 AM
I have 2.0T pistons and cylinders. PM me for details.
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 12-05-2014, 04:28 AM
this are my original pistons
Old 12-05-2014, 07:21 AM
These are the one that someone offered me
Old 12-05-2014, 09:55 AM
Those pistons looks like they were made for the later (2.2-2.4) heads and will not fit your early ones without a lot of machine work (never a good idea).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-05-2014, 05:38 PM
hello Steve, thanks for the reply . the manufacturer ln engineering has taged this set as this "Porsche 911 914-6 2.0 80mm Nickies inc. 9.5:1 JE Piston set" do all of the cylinder heads of the 2.0 lt engines are the same or they are different depending the compression ratio? thanks.
Old 12-06-2014, 04:55 AM
what can you suggest me to do with my engine?
Old 12-06-2014, 05:15 AM
The heads are all the same; only valve & port sizes differ. CR is determined by pistons.
I could make a hundred suggestions, but everything depends on your budget, performance expectations, and how the car will be used.
If you want detailed assistance, take a look at this: Performance Consulting | Rennsport Systems | Porsche Performance Systems and Support
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-06-2014, 11:23 AM
Thanks for all the information. One last question, are this pistons more adequate?
Old 12-07-2014, 07:31 AM
Those are 2.0 P/C's and will work just fine with your 2.0 heads.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-07-2014, 08:28 AM
