gumba's Avatar
distributor rebuild recommendations
I have a '76 euro distributor (237-301-001) 1 hose pot I'd like to get rebuilt. This is going into a modded bastard '79 3.3 bottom '76 3.0 top (heads-intake) motor.
thanks.
Harold
'79 930/DP935 (sold)
'68 VW 3.3 Turbo Crewcab
Old 04-09-2015, 08:31 AM
gtc gtc is offline
abides.
gtc's Avatar
IAE Inc.
Graham
1984 Carrera Targa
Old 04-09-2015, 09:31 AM
Might not be th the right distributor. I think the 3.3 engine uses the counterclockwise SC distributor.
Old 04-10-2015, 08:25 PM
thanks.
If you use the 76 Carrera 3 distributor, you will need the CW crank gear from the same engine to install on the SC crank which has the CCW one.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 04-10-2015, 09:02 PM
gumba's Avatar
The short block is complete, so the 3.0 is ruled out. My 2 reasonably priced options seem to be a 3.3 distributor w/msd or Electromotive xdi.
Harold
Old 04-10-2015, 09:37 PM
Walt Fricke's Avatar
Shouldn't any 3.0 (at least 78 or later) distributor work? My recollection is that the 2.7 and earlier distributors, in addition to being clockwise, are also narrower where they go into the case?
Or does the 3.0 turbo/76-7 Euro Carrera 3.0 case use the narrow distributor? My race motors are all crank fire, so I haven't had to do anything about distributors other than plug the hole.
Old 04-10-2015, 10:02 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Contact Aaron. He can build you what you need at what I would call a reasonable price.
There are two difference clockwise crank gears and miss-matching the distributor gear can be a disaster.
I could build you the distributor as well but given our history, that seems like a silly option.
Aaron Burnham
Burnham Performance
1071 Avenida Acaso ste.D
Camarillo, Ca. 93012
805-240-6931
https://www.facebook.com/BurnhamBros?fref=pb&hc_location=friends_tab&pnref=friends.all
rennwerks@hotmail.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 04-11-2015, 08:16 AM
gumba's Avatar
Thanks for the information. If there is no advantage to using the 3.0 distributor on the 3.3 motor I'd prefer to sell it to someone who needs it. The Electromotive xdi looks like a good choice.
Harold
Old 04-11-2015, 08:55 AM
resident samsquamch
sand_man's Avatar
Originally Posted by gtc View Post
Thank you for that!!! Interesting. Rather than go through the headache of tracking down the bearings and such for my 993 twin-dizzy, this could be a viable solution.
-jeff
Old 04-14-2015, 08:59 AM
gumba's Avatar
sand man, you may want to read Rarlyl8's experience with IAE,
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/859886-distributor-rebuild-recommendations.htmlhttp://forums.pelicanparts.com/911-930-turbo-super-charging-forum/859886-distributor-rebuild-recommendations.html
Harold
Old 04-14-2015, 09:11 AM
I would recommend Kurt at PartsKlassic. He recently did distributor for a friend and the work is very very good.
John- 78 Slick Top 930
"Illegitimi non carborundum"
Old 04-14-2015, 09:38 AM
gtc gtc is offline
abides.
gtc's Avatar
Yikes, I've only heard good things about him... until now.
Graham
1984 Carrera Targa
Old 04-14-2015, 10:18 AM
Kurt at ************ is one of those guys who seems to know his field backward, forward, sideways, and upside down. He's got distributors figured out. I told him of my difficulties getting the three Allen bolts buried down inside to release - I heated the distributor body, which loosened the bolts but melted plastic parts inside. He said he puts fractious distributors in his mill and mills off the bolt heads. When he gets the stuff they hold out he bores the stubs out and gets the remaining threads to give up and come out. I'd never be able to drill a hole right in the center of such a small bolt! But he has the tools and skills.
I've bought some distributor parts from him, and they are first class. I'd expect his work to be equally good.
Old 04-14-2015, 05:19 PM
resident samsquamch
sand_man's Avatar
And of course there's always the guy who already posted on this thread; Steve@Rennsport!!! Wish we could clone him and his shop for us East Coasters...
-jeff
Old 04-14-2015, 05:24 PM
Mahler9th's Avatar
Harold:
Hope that y'all are well and enjoying the Southwest. Have you considered JWE?
Jerry has done one for me and several other folks I know around here.
- Mike
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 04-15-2015, 08:31 AM
