Henry, With all the mods you did to the case why did you stick with the old IMS rather than update for the bearing one. Measuring the end play on that oldie looks cool though as does the cover.
Henry, instructive thread on a great engine as others have said.
One question if I may. It looks in the early photos as if you've not installed the crankcase wire mesh screens. I assume this is deliberate (or they went in and the photos were just a mock up), and I'd like to know your reasoning for leaving them out. Is this something you do on all your rebuilds? I have only rebuilt 2 911 engines, both stock, so I am a novice at best, and as a confession I noted the screen absence because I boxed up the last case and then spotted the screens on the bench, so had to reopen, clean, dismantle, fit, rebuild, reseal ...... Oops Mick |
Try not, Do or Do not
Shim assortments are available from 911 Vintage Parts Ken @760-731-4911 info@911vintageparts.com
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Thanks Henry - only ever dealt with early 70's and 60's engines so didn't know that - along with a lot else! So I infer you would actually remove them if you were rebuilding an early engine that originally had them fitted.
Mick |
Henry,
This is exactly the kind of build that gets me going. What fantastic work. The "stock" DeMan rebuilt motor in my 914/6 "needs" a bump up to 2.8 one of these days. What are you running for pistons and cylinders? I take it you are using high performance coatings at least on the pistons, anywhere else? How about cams, spec? Still on carbs as well? What hp are you looking at here? I would love to twin plug mine, but I can't rationalize the cost vs the small increase in performance or am I wrong? It happens. |
Main and rod bearings are dry film Moly as are the piston skirts. Piston domes are ceramic thermal barrier. Rockers are ground, rebushed with DU bushings, threads chased and the pad have dry film Moly as well before being cryogenically treated. Cams are Mod "S". 46 mm Webers rebuilt in house 270 hp ? on street gas. ![]() ![]() ![]() ![]() ![]()
Lord help me ... here comes that drool again !
Henry, any objective testing/observations done on the increased wear resistance afforded by the dry film coatings for a street engine ? Bill |
Oh yes, exactly what my dream engine would have. Love the pics.
What we didn't expect was the dyno results. With dry film and our rockers we found 13hp on two separate 2.7 RS engines. Both genuine RS engines produced more than 223 hp with no other modifications. These surprising results were a validation of our efforts to incorporate an old design with modern techniques.
abit off center
Nice rockers BTW
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Thanks Henry,
Any changes to the recommended oil type used when one goes with the dry film ? Still recommending the Delo 30W ? |
Chain fence eating turbo
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
The entire rocker rebuild process is done in house at Supertec with the exception of the Cryo.
They are available for sale in sets either outright or exchange from 911 Vintage Parts. info@911vintageparts.com or Ken @ 760-731-4911
Henry
Fantastic build as usual. Thanks for sharing. Put a kit of the plastic caps and plugs together so we can buy from you. Henry |
wonderful looking build! Im off to start something similar myself! excuse the stupid question, but what is that 4-blade fan on page 2?
This one?
http://forums.pelicanparts.com/uploads24/IMG_5862+11431272760.jpg That is the alternator/fan MOUNT, not the fan. Those four blades are stators that adjust and balance the flow off the fan. |
Henry,
Do you spray a moly coating on the parts? It looks from the rocker photos that I see a freshly bushed/ground rocker and then in the next photo, a dull finish from perhaps a spray coating? I've seen this used on cams to protect lobes during storage/transport/install/initial run-in. Always enjoy seeing your projects and have learned a great deal from your contributions to the Pelican community. Thank you. Cheers, Chet
Chet Dawes 1971 Porsche 911T Coupe 1974 Porsche 914 2.0L 2004 BMW 330i ZHP Sedan 2008 BMW X5 4.8i Sport |
We remove the old bushing Black Oxide the rocker Ream the bushing hole Press in the new DU bushing and burnish Surface the contact pad Coat the contact pad with Moly dry film (TLML 2) Treat the rocker to a Cryogenic conversion process Clean adjuster threads with 8x1.0 forming tap.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net Last edited by Henry Schmidt; 08-28-2015 at 09:19 AM.. |
Henry,
Thank you for all your documentation! What is the 3.0 oil pump flow mod you mention in the beginning of the thread? Peter |
