LinkBack Thread Tools Rating: Thread Rating: 7 votes, 4.29 average.
SWS911's Avatar
Henry, With all the mods you did to the case why did you stick with the old IMS rather than update for the bearing one. Measuring the end play on that oldie looks cool though as does the cover.
Old 07-24-2015, 09:23 PM
Henry, instructive thread on a great engine as others have said.
One question if I may. It looks in the early photos as if you've not installed the crankcase wire mesh screens. I assume this is deliberate (or they went in and the photos were just a mock up), and I'd like to know your reasoning for leaving them out. Is this something you do on all your rebuilds?
I have only rebuilt 2 911 engines, both stock, so I am a novice at best, and as a confession I noted the screen absence because I boxed up the last case and then spotted the screens on the bench, so had to reopen, clean, dismantle, fit, rebuild, reseal ...... Oops
Mick
Old 07-25-2015, 12:06 AM
Try not, Do or Do not
Henry Schmidt's Avatar
No real benefit to the update bearing.There are shims used for adjusting the end play and they were not availble for many years. We now manufacture a shim assortment making end play adjustment easy.
Shim assortments are available from 911 Vintage Parts Ken @760-731-4911
info@911vintageparts.com
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-25-2015, 05:33 AM
Mick
The windage screens were designed to isolate the sump oil from the spinning crank reducing drag (parasitic loss) and oil foaming. There was a service bulletin back in the 70s suggesting the windage screens actually created foaming. Then around 71 the engines were equipped with piston squirters that deposited oil on top of the screens exacerbating the problem so they were deleted from all engines in the early 70s.
Henry Schmidt
Ph: 760-728-3062
Old 07-25-2015, 05:48 AM
Thanks Henry - only ever dealt with early 70's and 60's engines so didn't know that - along with a lot else! So I infer you would actually remove them if you were rebuilding an early engine that originally had them fitted.
Mick
Old 07-25-2015, 06:36 AM
Henry,
This is exactly the kind of build that gets me going. What fantastic work. The "stock" DeMan rebuilt motor in my 914/6 "needs" a bump up to 2.8 one of these days.
What are you running for pistons and cylinders? I take it you are using high performance coatings at least on the pistons, anywhere else? How about cams, spec? Still on carbs as well? What hp are you looking at here?
I would love to twin plug mine, but I can't rationalize the cost vs the small increase in performance or am I wrong? It happens.
Old 07-25-2015, 06:41 AM
Originally Posted by Carbster09 View Post
Henry,
Pistons are JE (9.5:1) and cylinders are Mahle.
Main and rod bearings are dry film Moly as are the piston skirts.
Piston domes are ceramic thermal barrier.
Rockers are ground, rebushed with DU bushings, threads chased and the pad have dry film Moly as well before being cryogenically treated.
Cams are Mod "S".
46 mm Webers rebuilt in house
270 hp ? on street gas.
Henry Schmidt
Ph: 760-728-3062
Old 07-25-2015, 09:16 AM
Lord help me ... here comes that drool again !
Henry, any objective testing/observations done on the increased wear resistance afforded by the dry film coatings for a street engine ?
Bill
Old 07-25-2015, 01:50 PM
Oh yes, exactly what my dream engine would have. Love the pics.
Old 07-26-2015, 05:41 AM
Bill
We've been using dry film lubricants for years with great reliabilty as you might expect.
What we didn't expect was the dyno results.
With dry film and our rockers we found 13hp on two separate 2.7 RS engines.
Both genuine RS engines produced more than 223 hp with no other modifications. These surprising results were a validation of our efforts to incorporate an old design with modern techniques.
Henry Schmidt
Ph: 760-728-3062
Old 07-26-2015, 06:15 AM
abit off center
cgarr's Avatar
Nice rockers BTW
______________________
Craig
G2Performance
Old 07-27-2015, 12:54 PM
Thanks Henry,
Any changes to the recommended oil type used when one goes with the dry film ?
Still recommending the Delo 30W ?
Old 07-27-2015, 02:14 PM
Chain fence eating turbo
Originally Posted by cgarr View Post
Nice rockers BTW
Craig, you worked on those?
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 07-27-2015, 06:20 PM
The entire rocker rebuild process is done in house at Supertec with the exception of the Cryo.
They are available for sale in sets either outright or exchange from 911 Vintage Parts.
info@911vintageparts.com or Ken @ 760-731-4911
Henry Schmidt
Ph: 760-728-3062
Old 07-27-2015, 06:56 PM
Send a message via AIM to Hcarraro Send a message via Yahoo to Hcarraro
Henry
Fantastic build as usual. Thanks for sharing. Put a kit of the plastic caps and plugs together so we can buy from you.
Henry
Old 08-21-2015, 05:49 PM
wprater's Avatar
wonderful looking build! Im off to start something similar myself! excuse the stupid question, but what is that 4-blade fan on page 2?
Old 08-24-2015, 09:01 PM
This one?
http://forums.pelicanparts.com/uploads24/IMG_5862+11431272760.jpg
That is the alternator/fan MOUNT, not the fan. Those four blades are stators that adjust and balance the flow off the fan.
Old 08-25-2015, 05:14 AM
Henry,
Do you spray a moly coating on the parts? It looks from the rocker photos that I see a freshly bushed/ground rocker and then in the next photo, a dull finish from perhaps a spray coating? I've seen this used on cams to protect lobes during storage/transport/install/initial run-in.
Always enjoy seeing your projects and have learned a great deal from your contributions to the Pelican community. Thank you.
Cheers,
Chet
Chet Dawes
1971 Porsche 911T Coupe
1974 Porsche 914 2.0L
2004 BMW 330i ZHP Sedan
2008 BMW X5 4.8i Sport
Old 08-28-2015, 04:49 AM
Originally Posted by PropellerHead View Post
Henry,
Cheers,
Chet
Here is the process we use:
We remove the old bushing
Black Oxide the rocker
Ream the bushing hole
Press in the new DU bushing and burnish
Surface the contact pad
Coat the contact pad with Moly dry film (TLML 2)
Treat the rocker to a Cryogenic conversion process
Clean adjuster threads with 8x1.0 forming tap.
Henry Schmidt
Ph: 760-728-3062
Old 08-28-2015, 08:13 AM
Henry,
Thank you for all your documentation!
What is the 3.0 oil pump flow mod you mention in the beginning of the thread?
Peter
Old 09-01-2015, 08:25 AM
