1971 Proper Throttle Body and Velocity stacks
I found this in an earlier post....
Bottom port diameters
911T: 31.5mm
911E: 34.5mm
911S & 2.7RS: 37.8mm
Are these the throttle body sizes, or are these the velocity stacks sizes?
Does anyone have the proper part numbers for a 1971 Throttle Body / Velocity stack?
I believe this is the 911E velocity stack 911.110.314.1r ->> 72-73 911E stacks
but I don't have a number for the 911S
Also,
Is this the proper number for the 911s throttle body?
911.110.085.10 S
Thank you,
MaseratiSD
Old 07-05-2015, 09:54 PM
I thought that they were a little different.
Early
911T - Zenith Carbs
911E - 36/32
911/S - 38/36
Late
911T - 38/32
911E - 38/32
911S - 38/36
Part Numbers become complex:
Early Throttle Bodies up to 1971
911E - Sportomatic - 901.110.001.01 (left)
No number shown for RHS
- Manual - 901.110.001.00 (left)
901.110.002.00 (right)
911S - Manual - 901.110.034.00 (left & right)
Early Stacks
911E - Sportomatic - 901.110.043.01 (left & right)
- Manual - Shows the same part numbers as above
911S - Manual - 901.110.031.01 (left and right)
Late Type 1971 - 1972
Throttle Bodies
911E - Sportomatic - 911.110.083.51 - (Shown as exchange part)
911E - Manual - 911.110.083.50 (left)
911.110.084.50 (right)
911S - Manual - 911.110.085.50 (left & right)
Stacks
911E - Sportomatic - 911.110.031.01 (left & right)
911S - Manual - 901.110.033.01 (left and right)
Late 1972-
Throttle bodies
911T & 911E - Sportopmatic - 911.110.081.11 (left)
911T & 911E - Manual - 911.110.081.10 (left)
911.110.082.00 (right)
911E - Manual - 911.110.083.10 (left)
911.110.084.00 (right)
911S/RS - 911.110.085.10 (left & right)
Stacks (plastic)
911E - 911.110.065.02 (left and right)
911S/RS - 911.110.063.02 (left and right)
There are clearly some nuances between left side and right side I haven't understood and the PET does not make this clear.
There must also be detailed size differences which again aren't clear and I would be interested to learn more.
I also believed that there were 3 x variations on Plastic Stacks - 911T, 911E and 911S/RS but I can only find two variations on the PET???
Old 07-06-2015, 12:51 AM
I use this reference for MFI stacks and Throttle Bodies
Tom Butler
1973 RSR Clone
1970 911E - Sold but Never Forgotten
914-6 GT Clone
Old 07-06-2015, 03:14 AM
Try not, Do or Do not
Henry Schmidt's Avatar
Tom posted some very good information. Now here's where to get what you need.
Supertec rebuilds and restores MFI systems and can modify your system to meet any needs. Any size within reason.
911 Vintage Parts 760-731-4911 has a complete inventory of good serviceable used systems or individual parts.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 07-06-2015, 08:45 AM
DSPTurtle's Avatar
Henry, are those the throttle bodies you just finished for me?
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 07-06-2015, 09:43 PM
I have been interested in re-furbished TB's for some time and have a question that are slightly off topic.
When you bore a throttle body oversized does it affect the fuelling provided by the MFI pump?
I have a set of TBs fitted to a 2.2 litre 911 and clean out all the corrosion in the bore and correctly seat the throttle plate we have had to bore to 41mm and make a new throttle plate.
I am concerned that when we re-install them on the engine that we may have issues with progression due to a mismatch in the profile of the space cam and the new bore diameter.
I hope I am worrying about nothing but could use some advice.
Old 07-07-2015, 12:05 AM
The throttle bodies you sent us were painted. These are the ones we did for you.
Shiny new and ready to ship.
Henry Schmidt
Ph: 760-728-3062
Old 07-07-2015, 10:21 AM
tharbert's Avatar
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 07-07-2015, 12:58 PM
Wow,
Thank you everyone for the details, truly appreciated. I had read so much conflicting data I had lost the bubble.
Best Regards, MaseratiSD
Old 07-07-2015, 02:53 PM
[QUOTE=Henry Schmidt;8698394]
Henry,
Good day. I noticed in your picture here that the throttle body sizes have been written on the shelf:
36...34....31.5....28
I assume they are the bore diameters at the bottom of the TB's and if so, what model is the 34mm?
Thanks in advance.
Old 03-17-2016, 07:36 AM
Well?
Old 03-19-2016, 03:38 PM
Tags
911s mfi
