So far I like working with them. The big difference is I have much more control in the design of the piston. I get a solid model and theoretical weights prior to placing an order. Something I never got thru J.E. Other piston manufacturers do the same thing, but getting direct feedback from an engineers can be difficult.
Aaron. F.S. 1965 Solex engine w carbs/cleanerBurnham Performance https://www.instagram.com/burnhamperformance/ |
Schleprock
Thanks for confirming my suspicion & thanks for your insight on the CP pistons.
Kevin L '86 Carrera "Larry" |
Hello
It's often difficult to machine the plastic stacks, Did you bore them ? Philippe
www.injectionsystemes.fr |
I bore both plastic and mag stacks inhouse. These were bored 46mm top and 41mm bottom. They are matched to a set of throttle bodies that were bored to take 41mm throttle plates. |
Nice work !
Thanks!
Hi Aaron,
I just have to say i love your work on this engine and i want to do the samething on my 3.0! But i like to know howmuch hp and torque this set up will generate? Cheers,ferry |
Hi Ferry, Horsepower is around 280 hp depending on the exhaust you choose. With a little more cam and a little less exhaust you can see 300hp.
Hi Aaron,
Beautiful build. Congratulations. I was wondering which method and media you have used for cleaning the case and all the other alloy to this brand new level ? Cheers, Kerem |
Thanks Karem,
I sub contract to a company that specializes in surface preparation. They are usually involved in the manufacturing industry and prep castings and machined parts. The service is not cheap, but the result is a very consistent and appealing finish.
Nice build details Aaron.....good blend of mechanical know-how and aesthetic sensibility.
regard, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks Al, the engine turned out very strong and is a great fit for the car.
Max Sluiter
Ooh, Mark's got a new motor? Sweet!
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
oh yessss....that looks like fun!
regards, al
