jdbunda's Avatar
Good luck, Allen! I am in the midst of my rebuild, also. I can't yet boast of my success, but my mantra has been it's about the journey, not the destination. it is amazing how some of the simplest-seeming tasks can turn into hours of work, especially with rookie uncertainty. I hope your build goes well!!
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 11-07-2015, 09:42 AM
non-whiner
mreid's Avatar
What am I missing here? You have a Carrera, but it doesn't look like it has hydraulic tensioners.
Great project by the way!
"Too much is just enough."
Old 11-07-2015, 11:42 AM
Cars Ruined My Life
impactbumper's Avatar
my initial thought with the absence of oil line on the right bank. This might also explain the pistons.
Old 11-07-2015, 06:44 PM
Here's another angle from the front of the motor.
Old 11-07-2015, 07:01 PM
Right side.
Old 11-07-2015, 07:07 PM
Next steps on the way to 3.5 power
Engine and tranny are out and I am now breaking things down, sending them off for rebuilding and collecting parts.
Next collection on my list is ignition for the dual plug set-up.
I have a used 964 distributor that needs a rebuild kit - where do I get such a thing???
The dissy came with a twin coil pack and this housing.
I know I need new ignition cables etc, but what else do I need to make it functional?
I understand Andial signal splitters are scarce these days, so is this what I need?
Old 11-26-2015, 02:59 PM
RFP RFP is offline
RFP's Avatar
Check your PMs, Allan...
Rob
Old 12-01-2015, 02:43 PM
Head bolt issues
So in the process of removing the cylinder heads and completely disassembling the motor, 3 cylinder head stud nuts stripped and would not come loose.
Lots of lube and still no good. The rusted heads stripped in the inside before they would let go. So, cleaned the nuts, dried them well, put some burnishing paste in the hole to add to grip and retried the allen head nut removal tool.
Better!! Got 2 out of the three removed.
The last one is seriously stuck.
Ordered an ERWIN tool set with fat reverse thread removal bits to remove the stubborn nut. Once they came in, the final nut eventually gave way, but dang!! SO much force needed.
Turns out I have half steel, half dilivar head studs in the block.
Here's the offending party!
Old 12-24-2015, 08:14 AM
While I'm waiting
Now that all the parts are off to the machine shop, for cleaning and prep work for the 100mm cylinders, I am tackling the ignition problem for the twin plug plan.
I found this 964 dizzy, coils and ignition pack.
My plan is to see if I can use the ignition modules to manage the firing for the powerplant.
Old 12-24-2015, 08:25 AM
Counterclockwise?
Looks like you have it under control!
I would have experts check tolerances on the internals.
Rod
1986 Carrera
2001 996TT
Old 12-24-2015, 08:29 AM
Straightening a 3.2 dashboard
Waiting on engine parts to return, so Im working on other options.
I removed stripped, cleaned, painted and rebuilt the brake calipers.
Also, I have needed to recover the dash for a while.
The Texas heat has dried and shrank the leather on the dash, which peeled up the corner edges of the dash pad and warped it.
So I removed it, and it needs to be recovered, but it isnt straight.
Im not sure how to straighten it, so this is where I landed.
I mixed a 50/50 mixture of water based wood glue (Elmers or Liquid nails) and water.
I drew it up into a BBQ injecting needle and syringe left over from Thanksgiving.
I injected the mixture into the warped areas of the dash pad.
Then I heated the area with a heat gun and clamped the area with braces and clamps and left it to dry. The water helped to spread the 'glue' into a wider area, the heat moved it around a little more and activated the drying process as well as aiding in the softening of the pad to allow for shaping.
Last edited by Allan Kelsey; 12-26-2015 at 07:10 AM.. Reason: Better searchability
Old 12-24-2015, 08:41 AM
Extrude Honed Intake manifold
Despite all the mixed reviews over the power advantages (or lack thereof) of extrude honing the intake manifold in the 3.2 motor, in the interests of wot air delivery I elected to have it done.
Im trying to work my way toward 300 normally aspirated crank horsepower and believe this will aid in getting me there. I dont have the time/patience or budget to dyno the finished motor with and then without the honed manifold to finally put all the speculations to rest, but I can see how that would provide conclusive evidence of its effectiveness at different rpms...
Here are some before and after shots of the inside of the manifold.
Old 12-24-2015, 08:57 AM
Motor had 170 000 miles. Everything looked GREAT. Wear on the original cylinders was so minimal I could still see the criss cross pattern on the cylinder walls.
Normal bearing wear, but even the oil pump gear walls show no signs of wear.
Very encouraging.
Old 12-24-2015, 09:03 AM
Counterclockwise?
Very encouraging.
It is so impressive how these 30 year old engines last the test of mileage.
Wonder how the new ones do.
Rod
1986 Carrera
2001 996TT
Old 12-24-2015, 02:49 PM
scarceller's Avatar
Subscribed!
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 01-05-2016, 12:36 PM
Chain fence eating turbo
Do yourself a favor, and put a larger throttle body on. The stock 63mm frankly sucks. The ports outflow the TB I bet. I put a 75mm on and holy crap, the car is sooooo responsive.
Old 01-05-2016, 03:42 PM
scarceller's Avatar
Tippy,
Can you fit a 75mm onto the stock intake manifold?
What TB are you using?
You can also bore open the stock one up to 66mm but if you know of a way to fit a 75mm that would be real nice to see pictures.
With my 80mm MAF the restriction is the TB, my MAF with S&B filter are wide open at 80mm at the filter side of the MAF and 76mm at the side that mates to the 90 deg rubber boot. I think Allan is going to use my MAF for this motor. I'm currently working on his dual coils to fire them directly from the DME, no Andial Splitter needed.
Sal
1964 356SC (SOLD)
Old 01-05-2016, 05:43 PM
Originally Posted by scarceller View Post
Tippy,
Hey Sal, cgarr asked to, I guess a thread is due.
It wasn't easy, but knowing now how to, doing another wouldn't take me long at all.
Old 01-05-2016, 06:12 PM
scarceller's Avatar
Tippy,
Yes a thread just on this topic would be great!
Sal
1964 356SC (SOLD)
Old 01-06-2016, 05:19 AM
RFP RFP is offline
RFP's Avatar
Good morning, Allan... What's the latest progress?
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 01-09-2016, 07:50 AM
