914 JUNKIE
Phenolic intake spacers
Can you reuse the phenolic spacers if you use new gaskets? It's a 1987 3.2.
Chain fence eating turbo
I do. The gasket is what compresses.
Shouldn't be a problem. |
914 JUNKIE
That was probably misleading. The spacers compress too being a paper, fiber material.
Phenolic is a plastic, don't think the spacers are phenolic. |
914 JUNKIE
I swore they were a paper, fiber based material? Dang memory.....
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR, 993SS cams, Borg-Warner S366 turbo @ 1.2-1.5 bar, Treadstone full bay IC, 70mm TB, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MicroSquirt AMP'd w/GM smart coilpack, Bilstein coilovers, Tramont replica Speedlines (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel |
The aftermarket ones used on hopped up motors to help keep heat out of the intake runners and above are a hard plastic, and everyone reuses them. I don't know what Porsche used on a 3.2, but it doesn't make sense, since these "intermediate flanges" have a gasket on each side, that they couldn't be reused.
The only issue I've had reusing the plastic one is they tend to shrink over time. They shrink the most in the thick regions. This can affect the ability of the gasket to seal.
I resurfaced them by sanding them on both sides. I used a caliper to make sure each one was uniform thickness. And sanded them to equal thickness. Phenolic would be better i think. Higher temperature capability should mean better dimensional stability. |
Under the radar
What is a source for these? I need the ones that will cover the gap on SC heads when using Webers.
I am not afraid of making my own if I could find bakelite sheet....
I used these heat insulators on 930 CIS with aluminum injector blocks and the 12 stainless steel studs are now exhaust port studs and working well. They are made by PMO.
Heat Insulators |
PMO makes the correct spacer.
Under the radar
I read somewhere at PMO, that you must use a PMO manifold on an SC motor? Naturally, I can't find that link now...
But I did find this. Conversion Phenolic Kit - ************ Classic Parts for Air Cooled Porsche® Quote:
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 11-14-2016 at 10:13 AM.. |
The flange on the Porsche intake manifold is small and doesn't clamp the gasket on the CIS head. It is very easy to get intake leaks and idle popping.
The PMO manifold has a large flange and when combined with the PMO spacer the seal is much better. Downside of PMO manifold is they are taller and heavier. The throttle linkage needs to be reset. |
Under the radar
I have some REP manifolds, which I was told are early PMOs. Maybe they are the same? I will have to compare them to my Porsche manifolds after I pull them off my old motor.
REP is Richard apart of PMO
I just ordered a set of spacers this week To go between these two (Sorry my port is insured by my new shroud that I need to trim) Notice the elongated shape of the PMO flamge ![]()
73 RSR replica (soon for sale) SOLD - 928 5 speed with phone dials and Pasha seats SOLD - 914 wide body hot rod My 73RSR build http://forums.pelicanparts.com/porsche-911-technical-forum/893954-saving-73-crusher-again.html |
I have 46 mm carbs and 3mm ports
Richard said I needed his PMO 46/38 CIS insulator kit
