Valve springs for 930?
I am in process of a top end refresh on my 930, reground SC cams will go back in these heads. What valve springs should I put back in? Pelican has Porsche, OEM and German springs. I don't feel like I need heavy racing springs for this. Any suggestions from the engine builders, OEM and German are about $14 each. Porsche are about $40. Some of the springs in my heads have surface rust, so I would guess the cheap solution is replace at least the rusty ones, maybe all of them.
Old 01-17-2017, 09:05 AM
Member 911 Anonymous
DRACO A5OG's Avatar
Look for deals on Eibach Spring set. I found one for $85 on fleabay
'85 Carrera Targa
PCA/POC
Old 01-17-2017, 02:43 PM
When the heads are done the springs are pressure tested to make sure they are in spec for closing pressures. OEM is sufficient.
Bruce
Old 01-17-2017, 05:44 PM
The springs have rust, that is death to a spring, they will fail. I won't put them back in the engine. I am looking for a set of Eibach springs 20701.212 evs springs. If I can't find that I will go with next best OEM spring.
Old 01-17-2017, 06:07 PM
Found a set of Eibach valve springs thanks to a helpful Pelican member.
Old 01-18-2017, 03:13 PM
Ryan H's Avatar
2007 GT3
1982 911SC
1998 Integra Type R
Old 01-31-2017, 09:20 AM
