Member 911 Anonymous
DRACO A5OG's Avatar
Hewh good news. I think you are fine just make sure you go back to insure all studs did not come loose.
Yes, it is stock 3.2 pump. No I did not send out the pump but did have the IMS sprocket inspected. I simply cleaned it and checked for slop. Zero Slop but I did replace the hold down bracket/washers and of course the IMS bearings.
'85 Carrera Targa
PCA/POC
Old 05-30-2018, 08:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
DRACO A5OG's Avatar
Thumbs up Running Super Clean :-)
FINAL Update:
Smogged: PASSED with Flying Colors :-)
Seriously, she never ran so clean. One of the reasons I stuck to 3.4L build.
Cat On
Stock 3.2 Chip
Brown Cali Wire
Adjust AFR back to 14.7:1 from 14.3:1
Idle set to 800
Half Tank of Gas
200F Engine Temp on DELO LE 15W40
Tire Pressure at 32LBs but probably 34-36 after the drive there
'85 Carrera Targa
PCA/POC
Old 08-22-2018, 04:38 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
