tharbert's Avatar
#8 Seal
I ran into a problem installing the seal in the #8 bearing. The rubber perimeter coating "caught" on the notch. A portion of the rubber peeled back as the seal went in. Dummy me, I went back to Wayne's book and noted I should have put a bead of Curl T behind the seal. The damaged seal plus no suggested sealant = new Kaco seal ordered from Pelican.
72 911T 2.4 MFI
2017 Escape SE 2.0 turbo
2020 Honda Civic Touring Sport 1.6 turbo
10' Madone 5.2/17' Lynskey ProCross
Old 04-23-2017, 05:03 PM
You don't need a sealant there you just need to be careful pushing in the seal. Make sure there isn't a burr protruding into the circle where the seal goes at the bottom of the notch. Also push that side down slightly before the other side. In other words if you can't keep the seal perfectly square while driving it in, favor that side slightly.
Old 04-25-2017, 12:29 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
the sealant is for the #8 bearing itself:
Case Sealant - #8 Main Bearing
Old 04-26-2017, 06:40 AM
