Gasket sets, any difference?
All inclusive top and bottom end gasket sets. Porsche, Erhling, Wrightwood Racing, Victor Reinz, etc...
Any appreciable difference? Prices about the same... Only negative I saw mentioned was that VR oil pump rubber connector may be too short... Last edited by bpu699; 08-03-2017 at 11:34 AM.. |
I was told by a good friend that Wrightwood gaskets were the best. That's the route I went with. My friend owns his own Euro repair shop and is heavily involved with the early cars. Hope this helps.
1971 911T Irish Green Coupe |
Member 911 Anonymous
+2 Wrighwood Racing, don't chance it
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Chain fence eating turbo
I had luck with Victor-Reinz, but going 100% Wrightwood Racing this time.
Apparently, VR had a problem with the oil seals in between the case havles causes the oil pump to cavitate. Uh, that's really, really bad. |
I'll be the contrarian, I used Wrightwood on my last rebuild and have multiple gasket and o-ring failures since cured by other brand gaskets and rings.
Hmmm... clear as mud....
Anyone buy the "Porsche brand" gaskets? Or is that just pissing money away...? |
Sounds like wrightwood gets the nod...
Thanks guys... I see wrightwood makes a case gasket set... But nothing for the heads? Am I missing something? Last edited by bpu699; 08-03-2017 at 04:31 PM.. |
They make both
Constitutional Liberal
Jim “Rhetoric is no substitute for reality.” ― Thomas Sowell |
Is the gasket set for a 930 different than a non turbo? It's the same block and heads, confused... Is the victor reinz only an issue with the oil pump seals? $296. Porsche $400. Oem? $650? Not trying to be cheap, willing to spend money where it matters. But that's a huge price spread... Last edited by bpu699; 08-03-2017 at 04:56 PM.. |
call Ken @ vintage911parts.com
he works for Henry @ Supertech he will give you the current pricing for your application |
Pelican carries them, you just have to search
