Originally Posted by Trackrash View Post
It wouldn't be hard for JE to figure out what Mahle's alloy is. I bet Mahle uses a variety of alloys. Some of their pistons are cast and some are forged. That alone would require different alloys.
In fact "The majority of Mahle forged PowerPak kits are made with 4032" Which Mahle Aluminum Alloy Piston Is Right For Your Engine?- Modified Mustangs & Fords
And Mahle also uses 2618 at least for American motors.....
Mahle uses several different alloys. Air-cooled pistons are made from Mahle's proprietary material that nobody has been able to figure out precisely what it is and how they make it.,
Several years ago, I gave these things to both Alcoa and Reynolds and both told me they could not accurately replicate that stuff. The closest is 4032 (and its not close at all).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-06-2017, 02:49 PM
Under the radar
Trackrash's Avatar
I am assuming you are talking about Mahle' s forged pistons. So Mahle creates their own alloy? Wow.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-06-2017, 03:02 PM
Chain fence eating turbo
What a bummer. Struggling how they couldn't figure the alloy?
Old 12-06-2017, 03:05 PM
Sorry but that if Mahle is telling you that then it's total BS. They buy their aluminum the same silly way everyone else, including formula 1 engine manufacturers do, which is mostly from Alcoa. There is no magic proprietary aluminum they nor anyone else are using that F1 hasn't figured out or are using already, which they're mostly not as everyone is using 2618 or in MB and Ferrari's case it is said they are using a new 3d printed steel piston of sorts. Back away from that high-brow salesman kool-aid they're pushing.
No physical quantity completely explains its own existence
Old 12-06-2017, 03:41 PM
Under the radar
Trackrash's Avatar
3-D printed steel pistons, amazing. Steel honeycomb! Wow.
Still, it is my understanding that cast and forged pistons are not the same alloy. SC and Carrera pistons are cast, correct. But 2,7 RS pistons and Mahle motorsport pistons are forged. These can't be the same alloy, according to what I have read.
Gordon
Old 12-06-2017, 04:53 PM
Functionista
manbridge 74's Avatar
The alloy might be well known but the methods used to construct them would be different.
Where’s our resident metallurgist? He always has good info at times like this.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-06-2017, 05:08 PM
930 and 911 turbo Mahle pistons are also forged.
That's what I've heard anyway.
Old 12-06-2017, 06:55 PM
They have used their own proprietary forged alloys (in air-cooled engines) since 1966 that I'm personally aware of. Might have been before then, however I don't know.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-06-2017, 07:31 PM
Mahle people showed me this in 1966 when I first visited Europe: 2618/4032 didn't exist back then.
You can call BS all you wish, but I was there Sir.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-06-2017, 07:34 PM
It is indeed total BS they sold you on. 2618 and 4032 have been around since the 30s. 2618 was invented by Rolls Royce and I forget who did 4032, I’m sure it’s out there somewhere. Mahle is just being Mahle, or ‘extremely German’ as I like to call it sometimes in that they enjoy saying anything that doesn’t originate from Germany is shameful to be used. I deal with it in the ferrari world with mechanics there all the time. Meanwhile they’re outsourcing to Asia/turkey/Poland like everyone else. Total and complete high horse BS.
Old 12-07-2017, 05:08 AM
I see two potential fallacies here. What if Mahle uses their own composition? Would it NOT be 2618 or 4032 anymore if another element was added? Not sure, totally ignorant here. Second, why couldn't you analyze the shavings on an analyzer? We have one at work. I might try to shave some material off a piston and see.
Old 12-07-2017, 05:37 AM
Bruker makes a handheld analyzer that claims to identify alloys in 3 seconds and a complete chemical analysis in 5 seconds non-destructive.
Old 12-07-2017, 05:41 AM
Functionista
Does it tell what temperature the alloy was at when the forge hammered down?
I bet the method of manufacture is more important than the alloy itself.
Jeff
74 911, #3
Old 12-07-2017, 06:05 AM
Ponder the issue economically, as I’m 100% certain any company making anything is. Why on earth would a manufacturer currently making air-cooled pistons, which is an old tech with low volume, spend the capital on some proprietary material or process which is highly doubtful to be superior to 4032 or 2618. It’s makes zero economic sense. Mahle diesel pistons are a bit different, but that is a totally different concept. With Mahle groaning about making air cooled stuff anyway, they are not doing anything special.
Some years ago Ted Rutlands (yes, of Rutlands ferrari Parts, may he rip) approached ZF to make a run of ferrari synchros. ZF Germany promptly and curtly advised us the min order was $100k thinking that would make us go away. Ted being Ted quickly requested who the check needed to be made to. Long story longer, we had to fight tooth and nail AFTER they took out $100k and contact the state department to get them to make the run.
Point is, companies like Mahle and ZF could care less about some measly under 7 figures order so I promise you they are doing nothing all that special when they are made.
Old 12-07-2017, 07:04 AM
txhokie4life's Avatar
I find it interesting and annoying that Mahle sells pistons for American V8s but not air cooled Porsches? Unless of course you get the cylinder set.
I have a perfectly good set of cylinders so why can't I get Mahle pistons only?
I bought a set of Mahle RSR 3.8L 11.5:1 endurance pistons for my race build last winter.
Bought them from EBS and were drop shipped from Mahle. EBS had my Mahle cylinders reconditioned at the same time.
Still in engine assembly phase.
Mike
2015 Panamera Hybrid, 2008 Cayenne Twin Turbo
2001 996 GT2
1999 Spec Boxster, 1996 993 Cabriolet
1992 964 Cabirolet, 1975 911 RSR Replica Race Car
Old 12-07-2017, 07:34 AM
Alcoa did analyze the Mahle piston sample I gave them.
I was told they didn't know how to make that particular low-expansion, high silicon alloy and being metallurgists, took them at their word. The people I dealt with were certainly not stupid.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-07-2017, 09:08 AM
It probably had too many impurities to measure with a high degree of certainty haha. All in good fun folks.
Now who here wants to know how many factories in China Mahle have and just how long they’ve been established there.
Old 12-07-2017, 12:19 PM
More explanation would be needed. I've seen elements not make sense either we've scratched our heads over.
Old 12-07-2017, 02:17 PM
Well, how many?? Enquiring minds want to know... 😂
Old 12-07-2017, 02:18 PM
Everyone in Europe has been doing business in china since at least the 80s, but then started buying and rebranding existing factories or building their own factories since the 90s and probably earlier than that for others. Mahle has a min of 15 factories there as well as several in India and Thailand. When I say everyone is there, I mean everyone. Ferrari even helped magnetti marelli set up shop there.
Old 12-07-2017, 02:57 PM
