twin plugging
What parts are needed for installing a twin plug ignition, thanks jerry
I’m not an expert by any means but:
Cylinder heads machined for twin plugs Valve covers that accommodate twin plugs 993/964 distributor 2 coils Or 12 VW 1.8t coil on plugs and everything but the distributor above Some kind of stand alone efi |
Under the radar
or https://www.pelicanparts.com/cgi-bin/ksearch/PEL_search_2016.cgi?command=DWsearch&description=dual+plug
And spark plug wires
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
And spark plugs.
Thanks for the info. Any good sources to purchase a twin plug setup. Thanks Jerry
Lost of options here; may I ask what car/engine this would be used on?
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
78 row motor 98mm cylinders 10-1 cr,964 cams, ssi exhaust
CIS, carbs or EFI?
CIS, sorry about that
Chain fence eating turbo
IMO, if you’re going through the exercise of twin-plugging, might as well put either a MAP driven CDI box or EFI to take advantage of the part throttle gains you get from 3D mapping ignition
non-whiner
Or go old school like I did when I built the 3.2ss twin plug for my 904.
![]() Twin plug heads 12 plug distributor Twin coils Twin msd boxes
"Too much is just enough." |
1980 motor, 100mm pistons/cyls, 964 cams, large port Carrera twin plug heads, large port CIS air box, SSI exhausts and Electromotive XDi crank fire ignition. Why have to keep buying expensive distributor caps and rotors? The XDi system has infinitely adjustable timing and does away with the distributor completely. The compression on my engine is almost 11:1, timing is set at 8 degrees initial with 20 degrees added at 3000 rpms. Runs great on 91 octane pump gas!
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Fred, what make pistons and cylinders are you using, Slip in or machine in. Can you use 100mm with single plug. Like to stay with 91 octane, non ethanol fuel which is plentiful here. Not sure I want to twin plug yet.
I used Mahle 10.1:1 pistons with LN Engineering slip fit cylinders. Because of some machining having been done on the cylinder heads, the compression actually wound up being about 10.8:1 or maybe a bit higher. I don't think you can run the 100mm pistons on a single plug. You will pretty much have to go to twin plugs.
You can get a JE 100mm piston with a wedge dome for single plug through EBS. Not saying it's better than a twin plug.
Rick 1978 911SC |
