E28 Oiling Problem
I have an '87 535 with an oiling problem. It takes 20-30 seconds after the motor starts to develop any oil pressure. When it does come up, it jumps suddenly to 40-50 psi. I am preparing to drop the pan for a look. does anyone have any suggestions or experience with this problem?
In the shop at Pelican
Check the gauge and the sender first. The oil pump just doesnt kick on after 20-30 seconds, it runs the second you start the engine.
Yes, I know. I'm afraid that the pressure relief valve that's built into the pump, or the chain is hosed. I bought a new guage to test this thing out, and I couldn't believe what I was getting either.
So you are reading this off an external gauge? Yeah, there's something up with the relief valve then.
Thanks Jared. I appreciate your input.
