jgrm1's Avatar
Speedbleeder Install: Two Questions
I decided to replace my OEM brake and clutch bleed nipples with Speedbleeders. I ordered SB1010S for the front calipers and clutch and SB6100 for the rear caliper. I noticed that the OEM nipples have a flat tip on the seating end and that the Speedbleeders have a pointed tip on the seat.
First question, do I need to grind the tip off the Speedbleeder to match the OEM nipple or will it seat properly as is? I do not want to butcher these things if they will work properly in the calipers straight out of the box.
Second question, has anyone used a Speedbleeder on their clutch? If so, which part number? There are not enough threads on the clutch bleeder to engage the sealed threads on the SB1010S, so it leaks. I did grind the tip off one SB1010S in an attemp to make it work, but still only a few threads engage and it still leaks. I've been running a regular OEM bleed nipple on the clutch since the first fluid change with no problems.
Thanks for the input,
Jeff
BMW: 2024 R1250RS, 2016 R1200RS (For Sale), 2000 R1100S, 1975 R90S
Ducati: 2008 S2R1000, 1998 900 SS/FE
Norton: 1974 Commando 850
Triumph: 2020 Speed Triple, 1976 T140V Bonneville, 1973 TR7RV Tiger, 1971 T120R Bonneville, 1970 TR6C Trophy
Old 01-02-2007, 02:39 AM
have same part # SB. no problem using it on the clutch. to do my front, i removed the entire assy on the right fork leg, and threaded the SB directly onto the caliper. not sure it that's where your concern is or not. no, no surgery on the SBs necessary. they are a hard "press" to replace the grub screw, and don't thread all the way in, but they shouldn't leak. good luck.
"Wow I'm an idiot, thanks bikerfish!"
Harleys are like opinions, every a-hole's got one!
2001 R11S "lite", with a few mods.
2009 F800GS. has a better saddle. and other stuff. (sold)
2016 R12GSW 3Black. wow.
Old 01-02-2007, 08:23 AM
jgrm1's Avatar
I spoke with Speedbleeder today. The lady who answered the phone admitted that she's been told that the BMW guys grind the points off their SB1010Ss before installation. She is also sending me another SB1010S that has the sealant applied to the first thread for my clutch bleeder.
-Jeff
Old 01-02-2007, 07:18 PM
jgm1
Pull old bleeder out in goes speed bleeder: worked fine for F650 GS and 2001 1200C front. Both ABS. I never needed at rear or clutch as they were all within easy reach for finger twisting of bleed valve.
I attached MityVac at bleeder end, put the vacuum on and pumped brake. Front that is. And keep your unused left over brake fluid in the container in case you have to re-bleed. the left over fluid is at least as good as what you put in the bike, just don't come back to it 12months later.
Have fun. This is a 2 beer job.
tom rides and runs but 4 wheels no more;
added a '94 DR350SE goes to Mendocino, F650Dakar captain america sees Baja
R12S Red and Silver for cruising, the very first one was Honda C-90 way back when
Old 01-02-2007, 08:49 PM
Yep. Match the old nipple with a simple file. The bleeders are relatively soft. Careful, for the amount to file is small and goes quick.
As an aside, I assume sans the "A" in your tag that you don't have the ABS II. In the event you do, note this is my first experience dealing with this system below. To get the levers tight I was required to reverse bleed – something the Speeders don’t allow for. So instead of using them at the calipers, I used them at the masters. This I strongly recommend in any event since air is a devil at parking up here and doing so will inevitably make you life easier.
See generally: Help: Fill and Bleed ABS Proceedure & Tricks
Cheers,
T.A.
2000 R11SA, Black: Van der linde with chip, 5.5, smoked Spieglers, clear lenses, HID, hyper-lites, C-coated headers, CF stuff like belly pan and starter cover, x-stealth license, blah, blah..
Old 01-02-2007, 09:27 PM
During my battery install/suspension rebuild/custom wiring/valve adjustment/oil change/chip install/full detailing/fork seal/new front tire/starter terminal downtime I was thinking about doing speedbleeders and a bleeding/flush...
I have 2 SB1010 laying around from my Corvette, its the longer version of the one needed for the bike. Anyone know if these will work? Appears the only difference is that there is more threading.
The hex area isnt part of the sealing right? The threads and the > point do that right? So longer threads would be fine?
Matt
RIP Jeff Williams; RIP Brad Zimmerman
1989 K100RS - White/Blue, Remus; 1999 R1100S - Mandarin Orange, Remus, Ohlins; 2007 G650XCountry - Black/Silver, iStorm Luggage - Wilbers 75mm Lowered shock for the wife!; 2003 BCR #57 - Jeff's bike ; 2009 G477X - Akrapovic, WP Trax, SpeedBrain Goodies
2000 ///M5 - Custom Black & Blue, Dinan goodies
Old 01-02-2007, 09:31 PM
wood-d's Avatar
Re: Speedbleeder Install: Two Questions
I have the EVO ABS model which uses different SB's (8125L). I have never had to grind an SB for a brake application.
[Second question, has anyone used a Speedbleeder on their clutch? If so, which part number? There are not enough threads on the clutch bleeder to engage the sealed threads on the SB1010S, so it leaks. I did grind the tip off one SB1010S in an attempt to make it work, but still only a few threads engage and it still leaks. I've been running a regular OEM bleed nipple on the clutch since the first fluid change with no problems.
[/B]
The Speed Bleeder for the clutch is SB1010S. I had to grind the tip down a bit. There is a ball bearing seal on the bike that the SB needs to displace. Unless you grind the tip, the threads on the SB will not engage. I had no leaking problem by doing this. Once the bleed is complete, remove the SB and reinstall the grub screw (at least that is what I did). I can post/send a picture if you'd like. I think it will be difficult to tell how much I ground off.
2004 R1100S (2zars)
1957 Matchless G11
Old 01-03-2007, 03:33 AM
