LinkBack Thread Tools Rating: Thread Rating: 7 votes, 2.71 average.
Regnat populus
boxercup's Avatar
BMW Roundel Ok now...
Originally Posted by jduke View Post
It just seems a waste of talent for one of you guys not to at least TRY an FRK at the same time you're out doing a dozen runs with the resistors.
Come on, please, one of you guys take Robert up on his return policy and test his solution to what you guys have worked on and let the rest of us know what you think.
You've done all this work, we've kept up with your posts, don't stop this close to the finish line.
Thanks Gerry for your idea!
However, this is about a resistor and the effects thereof only. The Power FRK Module has NO resistors.
Let's see what resolves in this thread about resistance as a tuning medium.
Best to you!
Cheers,
Robert Foster
FOSTER RAD
LASER Engineering Exhaust Systems
RapidBike USA
Oakland Gardens, NY
Robert@FosterRAD.com
718-468-4680
Do not go where the path may lead, go instead where there is no path and leave a trail.
Old 10-21-2009, 06:37 AM
Uh....who me?
Bob Hancock's Avatar
Couldn't tell.....no sig diff. (I'm referring to the Aussie foam filters that BMW Atlanta sells.) I put them in both S bikes. I'll just keep the stocker in the R. It seems to run fine as is.
Bob Hancock
'20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss
"There are times when good words are to be left unsaid out of esteem for silence." St. Benedict
Banned
Originally Posted by OwenM View Post
Didn't work at all or didn't work enough?
The Unifilter was a definite improvement over the BMC filter I was using on the R12S, but the RT never had a significant problem with the standard filter to start with so the Unifilter made little differences.
A write-up on constructing and flow testing graphs for a $10 home-brew filter using foam media from Unifilter can be found at my website. The graph include flow measurements for stock paper and K&N filters with and without the snorkel. This should answer any questions about K&N versus stock versus foam (at least for the 1100 form factor filter).
Old 10-21-2009, 06:40 AM
Regnat populus
boxercup's Avatar
Thumbs up Not a Solution!
Originally Posted by Bob Hancock View Post
I tried that on two bikes...didn't work.
Greetings Bob,
Yes you are right. The filters will not tune a bike - They will only make demand for tuning as they free up the pumping losses.
Subjective opinions could be the placebo effect. Empirically there is a loss when added to a stock BMW. Worse with a performance exhaust (NO CAT) and NO tuning!
Thanks!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 06:41 AM
Uh....who me?
Originally Posted by boxercup View Post
Greetings Bob,
Thanks!
Hence my acquisition of FRK x 2. Problem solved. But you knew that.
Bob Hancock
Old 10-21-2009, 06:43 AM
Regnat populus
boxercup's Avatar
Question
Resistance tuning Ben!
Not air filters!
Stay on topic - Resistance tuning!
You spoke of it many times!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 06:44 AM
OwenM's Avatar
Best to you!
It would be comparing a
Please don’t use this thread as a platform to promote your product Robert.
I for one don’t give a rats what’s in a FRK, it really doesn’t matter.
R1200GS
R1200RT
Aprilia RSV1000R Factory
R1200S (sold)
Ducati 1098S (deceased)
Old 10-21-2009, 06:46 AM
OwenM's Avatar
Its not about flow as any filter has plenty of flow at 5000rpm.
R1200GS
R1200RT
R1200S (sold)
Old 10-21-2009, 06:47 AM
Uh....who me?
Please don’t use this thread as a platform to promote your produce Robert.
Trying to curb discussion, Shirley?
Bob Hancock
Old 10-21-2009, 06:48 AM
Regnat populus
boxercup's Avatar
BMW Roundel Shirly?
We have an angry lady here?
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 06:52 AM
OwenM's Avatar
Do you really think that we need to have another FRK thread?
R1200GS
R1200RT
R1200S (sold)
Old 10-21-2009, 06:56 AM
Uh....who me?
Well, under the filter topic, you more or less asked about the mid-range flat spot? All I was doing was responding to what solved my problem, which I think is good enough bandwidth to waste in light of the rest of this discussion. My two cents.
HEY....I just noticed. I don't have access to a "cents" symbol. Is it hidden in here somewhere? (Maybe I need to start a new thread on that. )
Bob Hancock
Old 10-21-2009, 07:00 AM
Banned
As careful as anyone should be in disputing your opinion, it is possible you haven't taken a close look at the R1100S filter, snorkel, or my write-up data. I measured the stock R1100S set-up as equivalent to a hole about 2.3 square inches.
Given the size of the TB throat, does that sound OK at 5000 rpm?
Please have a peek at my graph.
BTW, a "Bennie Duct" and sticky foam filter (which also filters better than stock paper) comes in at 5 square inches.
Old 10-21-2009, 07:05 AM
Regnat populus
boxercup's Avatar
Question Resitance Not FRK'IN!
Greetings,
This is about Resistance Tuning ONLY!!
That is the topic!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 07:06 AM
Regnat populus
boxercup's Avatar
Ben,
That is the topic!
You Spoke of it OFTEN!
Make us proud of you Ben!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 07:08 AM
OwenM's Avatar
I was providing information not asking a question. If the Unifilter did not work for you that s fine, my mistake I should not of mentioned filters here.
R1200GS
R1200RT
R1200S (sold)
Old 10-21-2009, 07:13 AM
Uh....who me?
No mistake Owen. These internet discussions ramble.... you know that. What you say brings something to my mind that I want to comment on and vice versa. Hard to mandate how the thread goes.
Bob Hancock
Old 10-21-2009, 07:16 AM
Regnat populus
boxercup's Avatar
BMW Roundel Lean!
Greetings,
Here is an average fueling graph of an R1200 series @ 40% throttle.
Lean Eh !!!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Regnat populus
boxercup's Avatar
BMW Roundel
Owen,
Stay on topic!
If we get into resistance tuning with filters then go for it!
Cheers,
Robert Foster
FOSTER RAD
RapidBike USA
Oakland Gardens, NY
718-468-4680
Old 10-21-2009, 07:18 AM
tm1100s's Avatar
OK, Foster, that's it.
Where do you get off posting hard data, anyway?
By the way, the hardware kit you sent had stuff I didn't even know was missing on my system!
tm
(R12, R11, R1) + 00 then S, S, /7
Old 10-21-2009, 07:22 AM
