BrianG's Avatar
Ohlins Install Problem
The new rear Ohlins shock does not quite clear the lower edge of the upper shock mount casting. There is some contact with the upper Ohlins casting.
Is it normal to have to clearance the edge of the frame's casting to gain some space?
Note
The top shock bolt is not fitting properly into its hole because of this interference.
Motorcycling in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
Old 12-27-2013, 03:44 PM
Brent
should clear with spare space, send it back
Old 12-27-2013, 05:11 PM
Registered Agitator
sgoodwin's Avatar
What he said, I have no such problem with mine either. For what they charge you it should fit perfectly.
Old 12-27-2013, 05:44 PM
R1100s
My Wilbers
Old 12-27-2013, 10:51 PM
My ohlins is very close like OP pictures. If I have a few moments (and remember) in the morning I will take some pics of it.
Matt
RIP Jeff Williams; RIP Brad Zimmerman
1989 K100RS - White/Blue, Remus; 1999 R1100S - Mandarin Orange, Remus, Ohlins; 2007 G650XCountry - Black/Silver, iStorm Luggage - Wilbers 75mm Lowered shock for the wife!; 2003 BCR #57 - Jeff's bike ; 2009 G477X - Akrapovic, WP Trax, SpeedBrain Goodies
2000 ///M5 - Custom Black & Blue, Dinan goodies
Old 12-27-2013, 11:21 PM
Brent
when I had mine rebuilt kyle said there were several major revisions to the r1100s rear
Old 12-27-2013, 11:27 PM
The one I had in the BCR was close too and showed signs of wearing after use. 10 minutes with a dremmel or file should fix it. On the bike side of course.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E.
Also residing in the barn my son's bikes:
'89 GS500ES, Ducati Monster 620 dark
Old 12-28-2013, 04:21 AM
After seeing those pix I went out and looked at mine. It's really close, probably just a few thousandths clearance, especially on the right side.
In fact it's so close that I'm going to take mine back off and add a few thousandths.
Old 12-28-2013, 05:42 AM
Yup mine is the same,just it you'll have a slight wear mark but no big deal.
Old 12-28-2013, 06:28 AM
BrianG's Avatar
Thanks guys!
Out comes the die grinder!
Old 12-28-2013, 07:38 AM
BrianG's Avatar
Some minor relieving of the frame's top shock mount casting on the lower and inside edge of the left ear, and a little more substantial work on the lower and outside egdes of the right side ear got me almost there.
It looks like extending the relief cut on the shock's reservoir neck might have been the answer, but I don't know where the channel is inside that casting, and an error there would be an expensive mistake, especially given the amount of metal taken off of that edge of the mount casting.
With the ears trimmed this much, the front of the shock's top casting was still just making contact at the center of the bottom of the frame casting. Just the lightest relieving of that spot with a Dremel sanding drum got me 0.050" clearance there when mounted and the swingarm at full extension.
The top mounting bolt is now a finger-fit into the hole with no contact of the shock to the upper mount casting.
Relieved Left Side
Relieved Right Side
Old 12-28-2013, 01:47 PM
Brent
just saying I didn't have to grind anything
I will look at mine when I am at the shop next week
Old 12-28-2013, 03:08 PM
BrianG's Avatar
Certainly, if the hole in the frame casting was set 1/8" down and 1/8" to the aft, none of this would have been necessary.
By the sounds of things from others, that variability seems to be within jig tolerances for this assembly. The OEM shock had plenty of clearance as it was.
Old 12-28-2013, 04:09 PM
given a couple more variables, like "flex" which we don't ever seem to talk about....
...looks like you're good to go, and even if it's on the edge, the only time it would clunk would be at full extension, which i believe is also AFTER the rear wheel has left the ground, which in turn could mean...
...if it does go full extension, the clunk might be classified as a "feature".
kind of like someone whacking a broomstick on the ceiling to quiet down the upstairs folks.
"bang-bang...what the hell is going on up there? knock it off!! take it down a notch!"
i've had dirt bikes that have done that to me...a nasty clunk in the rear at full extension when the rocker arm hit the frame.
it's made me pause and rethink my position (throttle position). most times i backed off.
most.
'04 R1100s. I changed a couple o' things.
Old 12-28-2013, 06:03 PM
BrianG's Avatar
most.
I wanted to have enough clearance to be able to try adding some length to the shock, since its length is adjustable.
Old 12-28-2013, 06:44 PM
Brent
if you really have to do that with what ohlins is shipping now, I would return it and get the wilbers,
ted porter here in the us is a good supplier.
I know that ohlins has various top designs,
Old 12-28-2013, 06:52 PM
adding length to the shock isn't going to change the fixed point clearance between the shock and the frame.
eventually a few degrees of angle will come into play, but the junction of the shock and frame that you're dealing with doesn't have any idea how long the other end of the shock is.
Old 12-29-2013, 06:30 AM
Exactly
Old 12-29-2013, 07:12 AM
BrianG's Avatar
Actually, it does, and for exactly the reason you state. As the swing arm drops the lower attachment moves forward. Without the added clearance achieved by relieving the casting between the ears I could just barely force the lower mount bolt into place when the shock was at its shortest configuration, so there was already contact. I could not get the holes aligned enough to even get the bolt into place when the shock was lengthened that extra 10mm.
I realize that the arc of swing arm movement doesn't cause much forward movement of the lower shock mount, but it was that tight.
Old 12-29-2013, 08:58 AM
All that money an you need to get a grinder out to make it fit...!!! Im thinking Ohlins need to Sort it... Mite be a good idea to send some photos off to ya Ohlins man, some feedback to the factory...
Jeremy.
Old 12-29-2013, 01:36 PM
