Detro996
Need Experts as this one is unusual.
I have a 2004 R1100S which I wrecked in August of this past year. I came up on a turn which tightened up dramatically and I pretty much forgot that I was riding with bags and laid the bike down trying to make the turn until the right bag hit the road, which I’m thinking the right cylinder would have hit at about the same time. But long story short I was fine, the bike not so much.
So I started the rebuilding process by rounding up parts here and on EBAY and BeemerBoneyard. I got the aluminum cage and the upper shock tower and in addition I needed an ignition switch and a gauge cluster and from there mainly it was just plastic. So I get to the point where I’m ready to make the bike a running ridable / rolling machine before I proceed to start working on the bodywork. I was unable to crank it after the wreck as the ignition switch was destroyed, so this was the first time it would run since the wreck. When I went to crank it, the thing was not running right. Basically it is misfiring on the right cylinder. While it is running it is spitting back through the intake and popping out of the exhaust sporadically. Before you start suggesting coil stick / coil / plug wire, I have spares in that I took the sticks out of my R1200S and I just so happened to have replaced the lower coil with new wires a few months back and I still had my old ones. So between those and swapping from left to right I came to the place where I knew my problem was the right cylinder and had nothing to do with wires or coil. It sits there and pops and spits until I unplug the two plug wires on that side and then it sits there and runs on the left without drama as in spitting and popping. If I do the reverse, which is to getting it running and so much as disconnect one wire on the left cylcinder it dies immediately, it will not run on the right cylinder. So I pulled the Fuel injector out to make sure there was gas, I even swapped the injectors from side to side, still no change. I just had the injectors cleaned and calibrated this past winter by RC as they are RC310’s. I’m not an ace / expert mechanic such that if I was I would not be asking for help, but I know when you have fuel and you have fire and the thing is not running right, typically the fire is happening at the wrong time or something in the combustion chamber is not where it should be when the fire occurs. So I take the cam sprocket cover off and line up the arrows on TDC and check the valve tolerances and they are totally in spec per the last time I adjusted them, which kind of blows my bent valve theory. At this point I was sure if I just pulled the head off my problem would be glaring at me, but I knew one more thing which needed to be done and that was run a compression test on it. I had to borrow a tester from a buddy and last night I checked it and I had exactly 229 PSI on both cylinders. As much as I was glad that I had 229 it made me realize what I thought I was sure of was no more and that it was back to the drawing board or I guess in this case the Pelican Parts Message Board as I’ve never asked for help before. I’m not sure if it is accident related or related to what was replaced after the accident, but I’m not sure where to go next. One thing of note, and that is the tach is not working and I felt like that was a problem I’d deal with later. Does anyone think it could be related. I’ve checked all the grounds and pretty much everything you can check visually. I don’t see any to reason to pull the head at this point. I’m starting to think that even though I have everything you should have to make one run, gas ,fuel ,fire, compression that perhaps the fire is not occurring at the correct time. I remember reading somewhere way back when about putting a plug on a coil stick and rolling the engine around to see if it fires or sparks when it hits TDC. Anyone have any other idea’s ??? |
Cam timing off one tooth?
I'll ride anything with two wheels as long as I don't have to pedal it (except maybe to get it started) |
Detro996
Underwater basketweaver
Check for an unseated throttle cable sheath at the TB.
'05 R12GS '08 HP2 Sport '16 GT4 |
What he said.
Richard 2010 F800GS '04 R11BXA, '01 F650GS, '98 CBR600F3 track bike, '75 RE-5, '76 RE-5, '81 GS400E. Also residing in the barn my son's bikes: '89 GS500ES, Ducati Monster 620 dark |
unsafe at any speed
X3 it won't let the throttle close all the way on that side. You have to look close where the cable fits into the adjuster.
Bill Swartzwelder 2002 R1100S Prep/ 2024 Tenere 700 |
Detro996
So I did the upgrade on the newer longer cable. But the cables are both seated into the hole by the throttle bodies. When I pull the throttle they both appear to pull the throttle bodies equally. I had planned syncing them once I got it running. But could those things being just a tad out of sink cause one cylinder to not properly fire |
Living on borrowed time!
229 psi is great compression.
I doubt cam timing moved. maybe, just maybe the hall effect sensor wires got gorfused. maybe. for giggles remove the BBS/ big brass screws from the tb's clean the gunk from them, put 'em in 1.5 turns out. WTH, at this point.. and investigate the TPS sensor as well. as we all know, with correct spark, at correct time, and correct compression and cam timing and fuel in correct quantity and correct time, it HAS to run. clear-blue swag; how's the battery?
Better a has-been than a wanna-be 'I am John Andrew Moffett of the Clan Moffat and by god I live, love, seek, fail, grieve and die as I so choose and I call no man master save me'. |
What happens when you unplug the stick coil and leave the bottom spark plug wire connected on the R/S. Thinking maybe not the stick coil, but the connector, or wiring from the harness to the connector may have been damaged. tjs
Detro996
Detro996
the spitting and popping subsides slightly. Then when you disconnect both on the right side it runs on the left cylinder without the popping and spitting. The popping and spitting back though the intake seem to be when the plugs on the right side are firing, but its like they are either firing at the wrong time or firing intermittently
Detro996
it might be grounding the ignition partially on that side, perhaps an HES wire is pinched. rubbed insulation off wire somewhere and arcing to ground?
it sounds electrical, as you are relating the issue.
or the main coil for that side is damaged...
Brent
measure the voltages at the injectors and coils with a scope if you have it to eliminate cut or broken
wires etc. with compression so close it would seem odd to be cams or valves or anything else. also of corse the hall sensors. I have had a bad main coil but it ran ok on the stick coil. |
Brent
also could be a broken spark plug
Detro996
Detro996
unsafe at any speed
Have you tried unplugging the tach? you mentioned you bought a used unit from a salvage yard? It is driven off of one side of the ign. system… it could be killing the spark, or the wiring harness going to it.
Detro996
Well, I can and have started it without the gauge cluster plugged in, so I don't think it would be at the gauge cluster. Can you tell me what drives the tach and where to the wires originate from, because like I said one issue since putting the new gauge cluster on is that the tach does not work.
