Two Questions
Will storage of the Boxster and subsequent re-connection of the
battery effect an emissions test? If you had a Boxster with 23K on the clock, and a good working clutch with the exception of grabbing high, would you change it now? Thanks fellow owners, AF
AJF 1998 Glacier White Boxster 1971 Fiat 124 Spyder 1999 Mercury Mountaineer |
Why not leave the battery connected and use a battery maintainer that just plugs into the cig lighter? It seems to do the trick just fine.
03 3.2L 986 Guards Red/Black -6 speed- -Litronics- -Carrera Light Wheels- -Bose Sound- -Painted Roll Bars- |
As long as your clutch grabs good, you should be okay. The fact it is high makes me think your pedal adjustment is off a little. usually a worn clutch will be low pedal and of course slip on a hard shift.
