Outside temp not working correctly
The outside temp on my newly aquired 99 Boxster is not reading correctly. Any idea why? Maybe a new sensor?
Thanks Mike |
Sensor is mounted in the front grill if you didn't know may be missing or out of position
How far off is it? Does it change, or does it always read the same? If it changes, does it change in response to the temp (eg. is it always x degrees off)?
Steve Wilwerding 1998 3.4L Zenith Blue Boxster 2009 Meteor Gray Cayenne |
Author of "101 Projects"
I've got an article on the front bumper that shows where this sensor is located, check it out here: Pelican Technical Article: Boxster Front Bumper Removal - 986 / 987
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
It reads between 120 and 126 degrees F.
I didnt see any pictures in your article. Mike |
Apologies for the hijack, but is outside temp gauge an option? I have a 2004 and don't believe I have one and wish I did.
The outside temp display was part of the OBC option. You can tell a car that had a factory one by the lower left hand stalk on the steering column. But early cars you could get the temp display only portion of the OBC just by having the dealer enable it. Others have enabled some of the features by the use of switches often on the radio surround.
Sounds like the temp sensor itself is bad - it just unclips. At they mention in this thread, you might try to swap with a known good one, if you have a friend with a Boxster.
See the inset of Photo 1.
-Wayne
