Guest
Posts: n/a
Hi i have a n12 engine, will not start, have fuel and spark? Will run up on easy start but wont even idle
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If the engine has fuel and spark but will not start, it has to be lacking compression. Check engine compression and timing.
- Nick |
Administrator
If it's running on ether, that tells me that the fuel isn't getting into the combustion chambers. When you say "has fuel", do you mean in the tank or getting sprayed by the injectors?
If the latter, it isn't getting enough fuel somehow. --DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
