Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
benben (guest)
Guest
Posts: n/a
Hi i have a n12 engine, will not start, have fuel and spark? Will run up on easy start but wont even idle
This post was auto-generated based upon a question asked on our tech article page here:
Old 01-18-2015, 05:45 AM
Nick at Pelican Parts's Avatar
If the engine has fuel and spark but will not start, it has to be lacking compression. Check engine compression and timing.
- Nick
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
If it's running on ether, that tells me that the fuel isn't getting into the combustion chambers. When you say "has fuel", do you mean in the tank or getting sprayed by the injectors?
If the latter, it isn't getting enough fuel somehow.
--DD
Old 01-18-2015, 08:43 AM
