Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Ryan (guest)
Guest
Posts: n/a
If we replace the battery with one of the exact same specs, would we still need to register the new battery or will the charge cycle etc. be the same?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article - Mini R56 - Battery and Connection Notes Replacement
Old 12-14-2015, 05:56 AM
Nick at Pelican Parts's Avatar
Yes. registration has to do with age of battery as well as size.
- Nick
Administrator
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
But it is only needed if your car has the Intelligent Battery Sensor. IBS cars have a plastic "box" on the battery ground cable, as shown in the following image:
http://www.pelicanparts.com/techarticles/MINI_R56/23-BASICS-Battery_and_Connection_Notes_Replacement/images_med/pic07.jpg
If you do not have that on your car, you should not need to register the battery at all.
--DD
Old 12-14-2015, 06:54 AM
