Suburban Conundrum
Looking for some sage Pelican wisdom here... I own a Chevrolet Suburban, purchased new in March 2001. The truck has been well cared for w/ 150k miles. The last few years, the "Burban" has not seen a lot of use, driven only occasionally. Last week, I fired it up for a trip to the hardware store. Pressed the brake pedal and it went straight to the floor-board. Brake fluid spewed out from one of the brake line couplings. Once the drama was over, I crawled underneath and discovered rust had perforated the line - once under pressure, the line blew. Subsequent to this, I've learned this is a common problem on Suburbans, Tahoe, and Chevy pick-ups of that period. GMC's are prone as well. Repair estimates from local shops range from $2k - $4.5K. Two shops I talked to stated flat out - they don't replace brake lines of this era. On-line, replacement lines run $200.00 or so. Google research and YouTube "how to" vids show it is doable for the DIY types, but a real pain in the a**, especially w/o a lift. Half of me says "pay the man" and be done with it. The other half says "I can do this". The third half of me, says to call a wrecker and haul it off...
So, all that to ask the Pelican brain trust - does anyone have any experience dealing with this issue? Any insight on level of difficulty or useful input on how to tackle the problem would be much appreciated! |
We have a 2004 Ford Excursion diesel (so the same size), and had this same problem last week. My son is a mechanic, so I went to Advanced Auto, and bought 2 quarts of brake fluid, and 2 straight sections of bendable steel brake line. These lines come pre-flared with fittings already on them in any length up to 6' long. The bill was $39, and it took him, and I (to help pump the brakes) a little over an hour to install, and bleed all 4 corners using his auto bleeder.
https://www.summitracing.com/parts/wmr-w87030?seid=srese1&gclid=EAIaIQobChMIiurM0Lbh4wIVh56zCh1fJAHWEAQYAyAB EgJIR_D_BwE |
You stated you don't drive the burb very often so there is no rush to repair , I bring that up as a positive . You don't have to rush to get it done tomorrow . GM made so many of these vehicles and as you stated they were prone to rust issues with the lines . Because of that there must be a bunch of vendors that make/sell replacement pre-bent lines . Search the web , find a vendor you are comfortable with and buy them . Take one off at a time and replace . When done do a brake bleed and your done . I would recommend at the same time " while you're in there " to replace the soft flex lines and maybe the pads . I am making the assumption that you are a DIYer and not afraid of doing the work .
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
"Better get back to the country, look around and find you a home" - OMDD
I've been standin' on the rock...
Rusty , messy pain in the arse but I do them all the time . Apparently , I am not charging enough either .
![]() You will probably end up replacing a few calipers, and sometimes getting them to bleed is harder than the line replacement . You can pull it off in a days time if you stay on it . No way I would junk the truck over brake lines. If the rest of it is nice, Id go at it .
No left turn un stoned |
Brew Master
To the OP, you might consider the line I mentioned above. My brother bought the line set for his 3500 and it was a PITA but his had the ABS valve. If yours has the ABS valve I'd recommend paying someone to do the job.
Nick Last edited by cabmandone; 08-01-2019 at 05:09 AM.. |
I went through this with my beloved 98 K1500. I bought a couple coils of copper-nickel line and bent and flared them myself.
There are a couple of tricky spots by the gas tank and around the engine/front suspension. otherwise I didn't think it was so bad. Fred is correct regarding calipers and bleeding. Replace the soft lines while you are doing it.
1981 911 SC 2013 Mini Cooper JCW 2017 GMC K1500 |
Member
i work for a Caddy store.
we do them all the time on Escalades and GMC/Chevy. some model years have a full OEM line set available from GM, check your VIN with your local dealer. and yes, those estimates are way high.....
Paul 91 964 C2 Targa sold (shipped back to the fatherland) 09 Cayman PDK 17 Titan 55 Sunbeam S7 Deluxe 70 Triumph Bonneville |
While I agree fixing the brake lines seems a reasonable project, what is the gain of keeping it around? It's nearly 20 years old and driven minimally, likely only enough to ward off issues like this. Would you trust it for a 500 mile drive at the spur of the moment? Has it really been displaced by a newer family vehicle? You certainly shouldn't sell it in an unsafe condition, but if today its brakes, next its radiators and transmissions? Maybe its a gentle way of getting you to move on from it and free up some driveway space
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
If you like the Suburban, fix the lines and keep on driving it. It is likely at the bottom of the depreciation scale and cheap it insure. Cheap transportation.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Would I spend $5k in repairs, no but a grand or two wtihout a doubt. Though here in the upper midwest it has a fender that was replaced after meeting a deer at speed and the fender is rusting while all the OEM stuff is in good shape. To the OP, I would do the lines. To do them yourself or pay someone is up to you, I don't know how much free time or disposable income you have. I have neither but would pay to have it done if it were mine.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Still Doin Time
My neighbor is a long life GM tech and he does these all the time on the side. He gets the replacements pre-bent from GM (that now have a coating) removes the body bolts, jacks up the body and with 2 floor jacks plus some sections of 4"x4" wood - cuts and removes old lines the slips the new ones in long ways above the bumper.
Says it takes him about a day, he charges $1K labor.
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
Retired Member
I had all the lines replaced on my Tahoe. It came in a kit, pre-cut lines made from stainless steel. My mechanic did it, I think I paid around $1000
80 911 SC sold 17 Tahoe 07 Z06 Corvette
I did lines on a van for someone with straight line from the parts store. I have a bender and it is not that hard. I also did not try to duplicate the factory routing. I just ran the lines down the the path of least resistance. Why run them along the fuel tank so they can rust out sooner ? I was also working free so I could do it my way.
![]() Anyway you can do it faster and easier if you do not worry about every little clip and bend the factory uses.
Keep talking, Im gonna put you in the trunk. |
How in the hell is the bill $4000 ?
I had a brake line replaced for $100
1986 Bosch Icon Wipers coupe. |
Gambler, PM sent. Thanks, Sam
Did you get the memo?
That sounds like crazy money, I’d at least get some other estimates. Definitely sounds like a truck worth fixing, even if you just fix it and sell it.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Still Doin Time
SamC. I sent you a PM
