https://en.wikipedia.org/wiki/Three-phase_electric_power Three wires with AC, but spaced 120 degree apart. You can do really neat stuff with it. I am puzzled that US still does 2-phase 230V thing. Over here, 3-phase is the norm. Only very small condos get singe-phase 230V feed, everything else is 400V 3-phase. Two phase is non-existant. My whole house is fed by 3-phase 16A fused cable. Basically everything runs on it: dryer, dishwasher, heating, hot water, hob etc. I went down from 25A and 16A fuse after converting to GSHP and still never tripped 16A fuse.
Thank you for your time, |
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
![]() Our 3 phase has 230V between phases (which most small single-phase stuff uses) and large loads (saunas, heat pump compressors) are connected to all three phases.
Banned
the cheap way is small 5 to 8 hp gas motor to drive the unit
Platinum Member
Unless you need that capacity, I would sell it and buy one of the quiet compressors.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Yes, exactly. And our "480V" 3 phase is virtually the same as your 400V. While it isn't "common", we do actually have lighting systems that use phase to neutral voltage on the 3 phase 480V (277 Volt to neutral). These will become rare soon, as companies move to LED lighting.
Motor
Don’t even bother with phase inverters. Just buy a 5 hp 230V 1ph motor and be done with it. Make sure it has a start/run capacitor as part of the package. Make sure shaft size is the same and motor baseplate is the same. Done and done.
Occam's Razor
For a 5 hp compressor you can go variable frequency drive, or rotary phase converter. you would need to buy one with a capacity of 7.5hp or 10hp for it to work reliably.
Better to just buy a 5hp 240v motor. it'll be cheaper. you need to pick one with the correct spindle to fit your pulley. I have a 3 phase, 3 hp grinder, a 1 hp mill and a 5 hp lathe. I put in a 10 hp rotary phase converter (better than a VFD imo). I got a Baldor 10hp 3 phase motor off of FB marketplace for $75 and bought an American Rotary panel off of eBay for $230. That will power all my machines much better than individual VFD's. 5 hp is about at the limit of where I would use a VFD. VFD's are really cheap for 1-3hp mills and small lathes, but 5 hp is pushing it.
Craig '82 930, '16 Ram, '17 F150 |
It's definitely more than I need but having a few air ports plumbed to my garage will just add to my man-garage ![]() Out of Space:
For my well pump I have a rotary phase converter, and transformer.... Your application sounds like VFD territory. Should be cheaper, however they do make solid state phase converter. My setup ran $2200. It's easy to wire three phase too.
At the end of the day. It's a lot of extra equipment.... Pros cons. I say replace the motor with single one phase. Especially since the only real advantage of three phase is the use of higher gauge wiring, which over a giant factory is economical. At home it's nothing to run 20 ft of 8 awd.
dolor et pavor Copyright |
Bland
Seriously - look at my post above. It will cost you under $175 to install a Inverter VFD and it will be way better - you can do a soft start, whatever you want. They are set up for a remote switch (read pressure switch). These things are slick.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
+1 on this idea
Sold: 1989 3.2 coupe, 112k miles |
Unregistered
My compressor was noisy as all get-out. I rigged up an intake snorkel routed outside the garage (short with as little restriction as possible) with a filter/silencer from McMaster Carr IIRC, cut the noise in half or better. |
