Curious Who Uses Walmart / Super Tech Oil?
Curious on if any of you use the Walmart branded oil (Super Tech), blended / distributed by Warren Oil Co.
I've been using it recently on an old engine that had been sitting for a while just to get a few hundred miles before a 2nd and 3rd oil change rather than the more pricey stuff.
Old 09-16-2020, 05:04 AM
Cars & Coffee Killer
legion's Avatar
I use it on my Mustang. Considering that it takes 8 quarts, I drive it 1,000 miles a year, and I have to change the oil every year, it makes sense to use a relatively inexpensive oil.
5 liters of VVT fury now
-Chris
Old 09-16-2020, 05:12 AM
Behind the Sun
I've used for decades on all my ford products.
Some of them reaching 300k
I change oil every 5k
Old 09-16-2020, 06:27 AM
I use it in my truck. Still use Mobil 1 in the Cayman.
Old 09-16-2020, 06:38 AM
^^^ He is slightly annoying, but he does some interesting stuff.
Old 09-16-2020, 06:40 AM
vash's Avatar
i dont remember the last time i was in a Walmart.
they run the lighting at depressing levels for me..
poof! gone
Old 09-16-2020, 08:53 AM
It has been over 20 years for me. I just hate the place. I am really afraid someone will take my picture and post it on the WalMartians web site!
My two cars are both 1980s cars with flat tappets. I use Brad Penn in both, only now it has a new name. 372,000 on the El Camino and 176,000 on the 911.
I am not using any Wal-mark oil in my car. YMMV.
Old 09-16-2020, 09:02 AM
I use their oil for diesel engines in my little, old tractor. I change the oil & filter pretty frequently since the hour meter doesn't work. I use RPM Delo in my larger tractor. When I had my truck, I used synthetic in it. I don't think I would have ever considered using Super Tech in the truck, although it may be good oil.
Marv Evans
'69 911E
Old 09-16-2020, 09:08 AM
225K miles on the '02 Silverado.
Super Tech every oil change since I bought it in '05 with 90K miles.
Old 09-16-2020, 09:31 AM
I buy a 5 quart jug of 0/20 Mobil 1 at Walmart for about $25. I saw Costco now has Kirkland synthetic motor oil...curious who makes that for them. I like Walmart...buy a lot of groceries there too.
Old 09-16-2020, 10:22 AM
canna change law physics
red-beard's Avatar
I use Amazon Basics Synthetic which is also Warren oil. I use it in my Ford F250 and in the Air Cooled Generators I support.
James
Red-beard for President, 2020
Old 09-16-2020, 10:27 AM
Arizona_928's Avatar
I use the walmart sythetic in gasoline generators, air cooled gas single and twins, and gas domestic trucks. I use the rotella t6 in all diesel applications.
Just change it regularly....
dolor et pavor
Copyright
Old 09-16-2020, 10:36 AM
Bland
unclebilly's Avatar
I use the TDH and hydraulic oil in some old farm equipment. It seems to leak no different than the more expensive stuff...
Old 09-16-2020, 10:55 AM
Team California
speeder's Avatar
I once went to look at a motorcycle for sale in the San Pedro area of Los Angeles. This is where the major refineries are located and the seller was an engineer at one of the major refineries.
I asked him what brand of oil he used and he said, “whatever is on sale.” He then showed me how to read an oil bottle or container. He pointed to the front and said, “all of this is irrelevant...” while pointing to words like, “turbo approved” and “high mileage...”
He also said that the brand was irrelevant. He then pointed to the “donut” with the viscosity and letter rating and said that was the only thing that mattered. SG, SH, SM, etc... Everything else was BS, according to this engineer from the refinery. I did not wind up buying his bike, which was probably a mistake since he took care of his stuff like few people I’ve ever seen.
Take that for what you will.
Denis
Old 09-16-2020, 11:17 AM
The rating is the floor, presumably the 'higher end' oil exceed the standard.
Or it's all a scam.
I'm cheap but I don't skimp on oil. Maybe on my son's car. Not on mine.
And the small savings on my single cylinder air cooled stuff isn't worth the effort.
Old 09-16-2020, 11:34 AM
I've run it in a few of my cars for probably 20 years or so. Haven't had a problem yet.
Old 09-16-2020, 12:14 PM
Eric Coffey's Avatar
Rating index is important for ID'ing the "minimum" quality standards, as mentioned above. There are many different variables and some pros/cons within them. Basically, the type and quality of the base oils + the type/quality of the add-pack/viscosity modifiers, etc. Another thing to look for is additional car manufacturer ratings. These are typically more strict (BMW LL-X, MB 229.X, etc.). If a particular oil meets several of those as well, then it's probably a safe bet regardless of the brand. Though, some of those 3rd-party ratings are application specific (diesel engines, etc.), and there is a big push towards fuel economy these days. So, "higher" ratings don't necessarily mean "better", and it's good to know what's what.
Here is an interesting tool for a basic/crude comparison between the different rating standards.
Old 09-16-2020, 01:05 PM
red-beard's Avatar
Sammy?
James
Old 09-16-2020, 04:08 PM
red-beard's Avatar
On large engines, the type and brand and additive package can make a big difference. We switched from a very good Shell Product to a Phillips 66 product and were finally able to get 1000 hours between oil changes. It also burned less oil and prevented cylinder silica buildup. At $8/gallon, each oil change is about $1,200.
Yep, $1,200 in oil every 6 weeks. And $1,600 in spark plugs...The oil filters are cheap at $35 each...about $25,000 per year...per engine.
James
Old 09-16-2020, 04:14 PM
Team California
speeder's Avatar
What type of engine/application is that? I did not realize that anyone made gasoline or spark engines that large(?)
Denis
Old 09-16-2020, 04:52 PM
