How much cement to use for flag pole footing
I'm installing a 20' flag pole. I'm using a 2.375 OD pipe that is pretty heavy. I bought a foundation sleeve that is 3' x 8", which hasn't come yet. Probably will have 18' exposed and 3' underground (my pipe is 21' total).
I'm wondering approximately how much cement I should be using, or what the ultimate size of the footing should be. I watched numerous youtube videos and everyone is different. One even used 10 80lb bags for a 25' pole - seems like a lot to me but I know I will need a decent amount. Just wondering what the group thinks while I wait for all my parts to arrive. |
My dad had a company put in a flag pole. It had all internal cords so no banging of the rope, and no way to steal the flag. It was 25 or 30 feet and it had a concrete footing that was 3 feet across and the pole and concrete were pretty deep. He did not want it to blow over in the Oklahoma winds.
I would bet there is a site out there somewhere that has all the specs for a footing for flag poles.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
A flag takes a lot of wind load.
I’m in the process of having an LED light installed on a twenty foot pole and it will be an 18” Sonatube buried 6ft deep if that helps?
Rutager West 1977 911S Targa Chocolate Brown |
You're definitely going to need one of these.
![]() And when he's done (few days at the most). Then you'll need a few of these ![]()
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Found this
my fence guy used six bags of cement per post..i know cuz i was paying for it.
if you were closer, i would run you a small rebar spiral scrap, and have you cast that in around your flagpole. i would imagine a 4 foot deep 2 foot wide cement foundation. would be hard to turn over.. it weighs damn near 2000lbs. a rebar spiral hoop would make it super sturdy and crack free..
poof! gone |
I’d think that an extra 2’ underground will be more helpful than extra cement. How about getting a sleeve for the sleeve, augering down 5’, and really planting that sucker deep? The effort of augering an extra 2’ is probably less than the effort of mixing and pouring a bunch more cement.
Vash is being lazy, by the way - he should do his civil engineer thing and calculate it - c’mon vash, you can do that in your sleep, or while you’re waiting for a fish to bite
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
If only he had one of those fancy HP42 calculators!
This is the sleeve that I bought. It's 3' by 8" with an 18" grounding rod at the bottom. My plan will be to surround it with cement to the bottom and now need to figure out total cement diameter. I watched a video at lunch where a guy used an 18" cement round for the top 12" and then below that he did about 30x30" footing. The flag pole will be sunk 3' (limited by sleeve) and have 18' exposed. The sleeve gets packed with sand after the pole is installed which enables you to make adjustments and get plumb perfectly.
although I don't have any of the round rebar that Vash has recommended, I will probably add some rebar to the footing as I have several pieces laying around. The Sleeve: ![]() The Pole: I don't know the weight but it is heavy (definitely not aluminum). It will be painted. ![]() Last edited by Tidybuoy; 10-14-2020 at 02:52 PM.. |
AutoBahned
vash is waiting for jyl to program the calculations in RPN
Found on a website that the pole is 3.66lbs per foot so that makes it 76.86 lbs.
2 bags, Vern.
Most flagpole kits come with instructions with this info but maybe your didn't, otherwise, that's what I'd go by.
Old dog....new tricks..... |
Make Bruins Great Again
Gez, the family in Brooklyn said all you need is one bag of quick set and two pails for a pair of shoes.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Hell Belcho
I wonder how much concrete that took?
Saved by the buoyancy of citrus. |
Concrete!!!
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Counterclockwise?
Would suck if you installed it not straight. lol
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
LOL... wasn't his fault the earth moved
everyone..this is what's bunching up URY's panties. he is correct, tho. i fumbled the term earlier as well, and i work with the stuff!.
![]() "Although the terms cement and concrete often are used interchangeably, cement is actually an ingredient of concrete. Concrete is a mixture of aggregates and paste. The aggregates are sand and gravel or crushed stone; the paste is water and portland cement."
poof! gone |
Thread Tools | |
Rate This Thread | |
