Bill Douglas's Avatar
Originally Posted by beepbeep View Post
I reckon there is self-inflicted resonance circuit and that outlet just happens to have right wire length for that oscillation to occur. Chinesium parts are very bad when it comes to spreading interference back to network. There is probably chopper step-down circuit in the heater which is not damped by condensator (saves 50c) and that is feeding back. Oscilloscope should tell...
I had that happen once. The electrician said I happened to have exactly the right amount of cable for this to occur
Wave forms bouncing back etc.
Old 03-05-2021, 01:10 PM
908/930's Avatar
As others have said check that plug under load and see if the voltage stays up, the poor connection can also be where that plug is wired from, do you know where the wire feeding that plug starts. Do you have anything driven by a VFD on that circuit, like an exhaust fan or fridge?
Old 03-05-2021, 03:09 PM
Platinum Member
dad911's Avatar
Plug in a heavy duty extension cord (lengthen the wire) and see if it goes away.
Old 03-05-2021, 05:41 PM
greglepore's Avatar
Just did this tonight, it doesn't. Moving the cooker from the outlet while using the cord doesn't help. There are three other outlets on the circuit (fridge on one) and it works fine on the other two (non fridge) outlets.
I did have led lights in a nearby range hood fail around the same time' Hood on a different dedicated circuit, maybe transformer is somehow causing rf, but it must be in the line, as I had the thing 10 ft away and it malfunctioned.
It worked fine on the troublesome outlet for two years prior.
Have warranty parts coming for the hood, will install. But issue is there whether transformer energized in hood or not.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 03-05-2021, 06:40 PM
908/930's Avatar
Probably the fridge compressor motor, or the fridge controls. Some older motors have a capacitor, and some newer ones use inverter drives, both can cause noise in the AC line.
Just the compressor cycling on is likely create a low voltage dip on that circuit, possibly resetting the controller.
Old 03-05-2021, 07:21 PM
Platinum Member
dad911's Avatar
The fridge is on the same circuit as the sous vide? If so, try the fridge on a different circuit with an extension cord and see if the sous vide works.
Refrigerators should be on a dedicated circuit, and are by code in new construction.
Old 03-05-2021, 07:36 PM
greglepore's Avatar
Its also on the same circuit as two other outlets that work with the sous vide, and one is closer.
Greg Lepore
85 Targa
Old 03-06-2021, 05:23 AM
Platinum Member
dad911's Avatar
You can rule out the fridge by using a heavy duty extension cord and plugging the fridge into a different circuit.
Old 03-06-2021, 06:53 AM
I see you
flatbutt's Avatar
Greg, time to sell the house while the market is hot.
Old 03-06-2021, 10:41 AM
greglepore's Avatar
Funny that you say that, we put an offer in on a place today...
Greg Lepore
85 Targa
Old 03-06-2021, 03:45 PM
UnRegistered User
billybek's Avatar
Is the refrigerator an inverter type compressor?
No idea if this could contribute but merely curious.
Bill K.
Old 03-06-2021, 06:24 PM
greglepore's Avatar
no clue-its 3 year old kitchen aid.
What's really got me stumped is that this all worked fine, fridge, sous vide, everything, for almost 3 years.
Greg Lepore
85 Targa
Old 03-07-2021, 05:09 AM
Gon fix it with me hammer
svandamme's Avatar
Bit surprised nobody has yet suggested to check the ground on that socket
Stijn Vandamme
BIMDIESELBMW116D2019
Old 03-07-2021, 09:07 AM
Platinum Member
dad911's Avatar
^^ post 20..... but current should not be travelling through the ground.
I still think it's a poor connection somewhere.
Measure voltages under load, or see if a simple old-style incandescent light plugged into the same outlet flickers when running the sous vide.
Old 03-07-2021, 04:18 PM
svandamme's Avatar
it shouldn't but it could be that the ground is not ground
and some other appliance leaks. and affects this one or vice versa
Stijn Vandamme
Old 03-08-2021, 12:18 AM
I cook sous vide using an anova immersion circulator, which has a built in pid temp control. When plugged into a specific outlet in my kitchen, the unit continues to heat beyond the setpoint.
The fact that the device heats, and heats beyond the set point, implies that he probably does not have a power issue.
Does the device even have a ground pin?
Have you re-tested your hypothesis? You could just have a flakey device....
Old 03-08-2021, 05:51 AM
greglepore's Avatar
Yes, the device has a ground pin.
Yes, I used a different brand immersion circ, brand new out of the box (initially thought mine was bad) and it behaves the same way on this outlet, but fine on the others.
Tested for ground and load, didn't test for leakage to ground, will do that, but have swapped outlet with no effect.
I see dead people....
Greg Lepore
85 Targa
Old 03-08-2021, 07:30 AM
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-08-2021, 02:54 PM
