Can anyone help ID these things?
I don't think they are rivets.
I have a half a small peanut can of them. TIA!
Old dog....new tricks..... |
Yeah, it's a 1987 US Penny.
Hell Belcho
They look like parts to a air hammer. A really SMALL air hammer
Saved by the buoyancy of citrus. |
The threaded spikey thing looks a lot like the optional spike feet that came with my Caldwell front rest
Model Citizen
floor speaker spikes?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Kantry Member
Perhaps spikes for a tripod?
The threads would provide adjustment. Just guessing. Best Les
Best Les My train of thought has been replaced by a bumper car. |
I see you
A masonry anchor?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Brew Master
The thing on the bottom right is a 1987 penny.
![]() Baz If you don't mind me asking, how do you end up with half a small peanut can of stuff and you don't know what it is?
Nick Last edited by cabmandone; 04-03-2021 at 02:33 PM.. |
anchors for tooth implants
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Platinum Member
Looks like some sort of anchor, like a manual version of this:
![]() If you drove the pin into something, would the washer move on the shaft?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
They are galavanized, so probably meant to go outdoors. Maybe fence hardware, or fasteners for metal siding, like on a barn or something.
Thanks for the laughs and guesses so far. I don't feel so bad now not knowing what these are.......
Pretty sure they go in your nipples ............ go ahead and jamb the pointy ends in and let us know how you like the look
The knarly S hooks are for your partner to hang onto .......... maybe you can use a fishing lure to spice things up
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
I see you
Navin Johnson
![]() Looks almost like this McMaster The pointy things look like some sort of turning center/transfer not sure
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 04-03-2021 at 04:38 PM.. |
Sent the pic off to my oldest brother who is a machinist and metal fabricator.
He said some kind of drive anchor. Said the little curly things were some kind of 90 degree clasp someone came up with. I will update the thread as I discover more info.....
Leadfoot Geezer
Don't know about the bent wire things, but both the threaded piece and pin with sharp points might be devices used to transfer hole locations from one work piece to another. I used something similar to line up thru holes for screws with their threaded counterparts on a removable panel for a cabinet. Screw or press the pin into a hole in one piece, then when you bring the two pieces together, a witness mark for a mating hole is left by the sharp point.
'67 912, '70 911T, '81 911SC, '89 3.2 Targa - all sold before prices went crazy '13 BMW 335i coupe - current DD '67 VW Karmann Ghia convt. & '63 VW Beetle ragtop - ongoing projects Last edited by rcooled; 04-04-2021 at 12:49 PM.. |
don't know what they're called. but my dremel tool came with a bunch of them.
1971 R75/5 2003 R1100S 2013 Ural Patrol 2023 R18 |
IDT the links and the pins are related.
The hooks look like something from an old style overhead garage door spring. I've seen those someplace and I've been thinking about it since yesterday. And the more I look at the pins the more I see a masonry drive anchor. The washer moves up as it is driven to depth. Probably powder actuated type tool. |
