			 Ayo Irpin, Ukraine!
			Made a baby?
	Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air  |
			 I see you
	Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out."  |
			 Ayo Irpin, Ukraine!
hahahha...
			you just filled my PPOT laugh quota for the week!! see you all next week.
	poof! gone  |
	No left turn un stoned  |
			 Preferred pronoun:Maestro
And by the (unfairly stereotypical) looks of it, an Italian one.
			_
	When in doubt, use overwhelming force.  |
			Changed the oil in a small engined motorscooter?
			Interestingly, that is pretty close to how I drain the oil from the MFI pump on my car.  Instead of the turkey baster, though, I use a big syringe.  Long hose just like that, snaked in the upper right rear square cover on the governor mechanism, until I can feel it go down past the fly weights.  I only have to do this because I isolated the MFI pump from the engine oil supply, like the RSR's and such.
			I used to use a gear oil plunger pump many years ago, but the big syringe is actually easier and cleaner. Early version (like 15 years ago) of my 3.0, before I upped the compression and twin plugged it:
	Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world"  |
			 A Man of Wealth and Taste
			Dropped a load and you are proud of it!
	Copyright "Some Observer"  |
			 Model Citizen
			Colonoscopy prep.
			The night before.
	"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome"  |
			Cut your little finger off?
			 Kantry Member
			Changed the oil in the bike you bought a while back?
			You have to admit, this is a funny crowd. Best Les
	Best Les My train of thought has been replaced by a bumper car.  |
			 weekend wOrrier
		![]() A last ditch attempt to avoid the dreaded "one in a million doc" conversation? Last edited by LEAKYSEALS951; 09-30-2021 at 04:47 PM..  |
			 Edministrator
			^ that's the best reply I've seen here in months!
	Good post? Leave a tip! O - $1 O - $2 O - $3  |
			Oil change. Overfilled and pulled out a quart.
			Topped up the antifreeze and changed the oil in anticipation of the long winter. Many times I watched my Dad do the same thing. The way the little balls floated when you got the antifreeze mix correct seemed like magic to my young self. Still does, actually.
			MRM 1994 Carrera Last edited by MRM; 09-30-2021 at 06:16 PM..  |
Think it was Woody Allen who said death is like a colonoscopy...you go to sleep and all is peaceful.  Life is like the prep...
	"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.)  |
			Had an enema?
	"A little nonsense now and then is relished by the wisest men." Wonka  |
			Gave yourself a mineral oil enema?
