LinkBack | Thread Tools | Rate Thread |
At my Mom's house they had storm shutters installed years ago but unless they are maintained on a regular basis of course the fasteners are going to get bound up.
In this case they are hex head bolts & normally you'd only have to use this tee- wrench but they have sat for several years so are now a bit frozen up. I plan to apply Kano Aero-Kroil penetrate, spray this CRC Freeze-Off product on the fastener itself, and then gentle wiggle back and forth with vice grips. My older brother, who is a machinist by trade, had this suggestion: Quote:
Thanks for any opinions!
Old dog....new tricks..... |
Heating the area around the screws should cause it to expand which should make the bolt more "loose." I've also wondered about using something to freeze the bolts, like the stuff for freezing a wart off or an upside down can of compressed air. Freezing the bolt should shrink it (I would think) which should accomplish the same thing.
I've heard that installing interference fit bearing races can be done by putting the race in the freezer for a while, or putting the hub in the oven for a while (or maybe both). But this is all theory or hearsay. I've not had to use heat to remove a bolt before. I'm sure some of the other guys that have first hand experience will chime in.
The answer is always heat ! . As stated above, try to heat the metal surrounding the fastener . That should make the metal expand, looseing the fastener .
I like to make it glow , but may not be safe in your situation . This is the magic trick for working on cars in the rust belt. Especially exhaust fasteners . I just did some work on an ML 350 that lives at the beach today . It was every bit as rusted and corroded as any rust bucket here in Pa . Good luck friend
No left turn un stoned |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Parrothead member
It's the same way I use to install piston wrist pins.
I put the pins in the freezer for a few hours. and I heat the pin end of the connecting rod. It expands the rod just enough to slide the pins in. Just have to work fast! .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I'll keep everyone posted on results as appropriate.
Thanks, Vinny!
Heat but looking at that, there are other factors involved, looks like stainless steel fastener in aluminium, add water, guaranteed to corrode. Fortunately it is a socket head so you have a chance, heating and adding penetrating oil and some time gently wiggling them to get oil deep in the threads and you should get them out, don't try to remove until they rotate freely, With aluminium against stainless you will end up with easy galling. Better replace with grade 5 zinc aluminium coated SHCS vs stainless steel.
87 930, Last edited by 908/930; 04-12-2022 at 06:27 PM.. |
I like your idea better though and will look into it. Thank you!
Platinum Member
That must have been a popular brand. I remember them well, had them on a condo until the association replaced all windows with hurricane glass.
I was able to get most of them working again with penetrating fluid, don't remember the brand, but time was on my side. Soak, come back in a few months, soak again. A few I drilled out, or got the aluminum rod out, and drilled/tapped a new hole. My bigger issue were the rollers at the top. Those bolts were permanently stuck.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Almost Banned Once
Heat always helps when trying to remove a stuck fastener but you also should be using "good" tools.
Wera make "Hex Plus" Allen keys. They're not cheap but they have a special shape so they bite into the corners of the fastener. They work really well for difficult fasteners. When I first saw them I thought they were just another gimmick but they really do work. And make sure you take the time to clean out the socket on the screw. https://www-de.wera.de/en/great-tools/hex-plus/
- Peter |
If you are looking, McMaster sells the class 12.9, alloy steel socket head in Zinc aluminium coated.
87 930, |
Control Group
Put anti sieze on when you reassemble. I like using fasteners that are same metal as the frame
She was the kindest person I ever met |
Battery powered impact, with a good hex key socket. Bump it a bit loose, bump it a big tight. Back and forth, back and forth. Don't go to town, and don't use a pneumatic, just your basic 12 or 18 volt tool. It won't be able to break the bolt, and probably won't be able to chew the head up, but it'll be able to crack things loose.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Hmmm...
I use Kroil from the can, and apply it with a good oiler. I agree on copper grease "anti-seize". I would probably try an impact tool. I have a Gedore impact driver that you hit with a hammer in situations just like this. |
Almost Banned Once
Expensive but you wont regret it Sir Baz! ![]() Search "Hex Plus" on Google.
- Peter |
Control Group
Firm rap on the head of fastener will get them loose sometimes
Pete, what's special about those?
I bet a drop of oil overnight, they will come right out.
